spare tire different
Maverick77
Randy
Dodgeville Wis.
2026 Maverick Lariat
Well, initially, I thought so - it was pretty tight so I drove it a couple days and then got underneath and looked and those puncture teeth were sitting inside of the tread which I didn’t like so I ended up doing like some others and bent the teeth down so they weren’t sticking straight out. I think it’s fine now.
My 2019 F-150 did not have any teeth and was not impressed when I was under the truck adding Mabett underbody cover. My thoughts are to grind the teeth down to nubbings and add a slit rubber hose over them IF I attempt a full size 19" spare. Just finished installing sound deadener in the back of the cab. Additional LED bed lights next, install side decals across the lower portions of the doors, and then maybe the spare tire episode.
Jensen3
Louisville KY
2025 Maverick Lariat
Any chance you can tell us Lariat owners which 19" wheel did you get? I learned from my F-150 days that Ford usually has a different offset than most aftermarket wheels.
https://www.carid.com/rt-wheels/19-steel-wheel-5-lug-x49518-black-1966858937.html
CARID.COM
SKU: 2082661996​
RT® - 19" STEEL WHEEL 5 LUG X49518 Black (19" x 7.5", 5x108 Bolt Pattern, 63.4mm Hub)
19" STEEL WHEEL 5 LUG X49518 Black Wheels by RT®. 19" x 7.5", 5x108 Bolt Pattern, 63.4mm Hub.
mwelby
mwelby
New Mexico
2025 Ford Maverick 2.0
Yes, if I still perceive there’s a problem my thoughts were to get my cut off wheel and just cut them all off but that rubber hose idea to cover any sharp edges is great. Much appreciated.
Remember you want that spare to rupture to help the crumple when someone rear ends you.
I was wondering about that. Thank you for asking.
I figured the engineers designed those teeth there for a reason.
CaliMav68
JL
Ohio
2022 Maverick Lariat AWD EB
Really…. These new questions that have been asked and covered over and over get old!
If there wasn’t the internet I could understand
I have an idea …. Google?
And yet you take the time to read and respond to a topic that you are bored with.....
OP wanted to ask actual people, not the internet with it's boiled down answers, about a topic. That's why we're here. Novices and "experts."
Actually - the idea is the Google search function on MTC throws you to the threads with actual people.
Actually a search of Google for MTC does the same.
I'll bet the 2nd link is great!
(perhaps title is a tad long)
And it's not even in the 5 similar below.
https://www.mavericktruckclub.com/f...he-pathetic-factory-bicycle-wheel-spare.55137
Ford Maverick spare tire different 1778608589889-n9
Fibrepunk
2023 Ford Maverick XLT Hybrid
anyone get a different spare tire than the other 4
Donut: Compact Spare: 155/70/17
Ford's full size spare: Primary Spare: 215/60R17
None of the two above matches up with the mounted tires' diameter that come with the truck.
BDennis
Bruce
So Cal
Yes it is a problem. So if you get a flat DO NOT USE IT. Walk to a tire store with the flat tire under your arm and buy a replacement. Joking of course. Answer this. When was your last flat tire? Mine was in 2010 and I put the spare on and drove to a tire store immediately. Had 2 tires put on, because they only had 2 alike, drove 300 miles for work. Tire store ordered 2 additional tires and a week later I had them put on.
No, what it means is if you get a flat front tire on a FWD you jack up the side of the truck, place the rear tire on the front and the so called full size spare on the rear. Flats sometimes occur far from a tire shop.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
So what am I supposed to do with AWD? Technically it's fwd the majority of the time. I'll roll the dice and put the conventional spare on which ever corner has a flat.
jonshep
SW Oklahoma
Yep that 215 **** is your full size spare. I have had mine for 2 years and as far as I know there is a side wall on the bottom facing side of the spare, not sure about the upside. 🤔
