- First Name
- Mike
- Jul 26, 2025
- Louisville KY
- 2025 Maverick Lariat
- Engine
- 2.5L Hybrid
That's the one!What's a micro spare?
I agree if you're talking about one of these.
My 2019 F-150 did not have any teeth and was not impressed when I was under the truck adding Mabett underbody cover. My thoughts are to grind the teeth down to nubbings and add a slit rubber hose over them IF I attempt a full size 19" spare. Just finished installing sound deadener in the back of the cab. Additional LED bed lights next, install side decals across the lower portions of the doors, and then maybe the spare tire episode.Well, initially, I thought so - it was pretty tight so I drove it a couple days and then got underneath and looked and those puncture teeth were sitting inside of the tread which I didn’t like so I ended up doing like some others and bent the teeth down so they weren’t sticking straight out. I think it’s fine now.
Any chance you can tell us Lariat owners which 19" wheel did you get? I learned from my F-150 days that Ford usually has a different offset than most aftermarket wheels.
| https://www.carid.com/rt-wheels/19-steel-wheel-5-lug-x49518-black-1966858937.html | ||||||||||||||||
Yes, if I still perceive there’s a problem my thoughts were to get my cut off wheel and just cut them all off but that rubber hose idea to cover any sharp edges is great. Much appreciated.My 2019 F-150 did not have any teeth and was not impressed when I was under the truck adding Mabett underbody cover. My thoughts are to grind the teeth down to nubbings and add a slit rubber hose over them IF I attempt a full size 19" spare. Just finished installing sound deadener in the back of the cab. Additional LED bed lights next, install side decals across the lower portions of the doors, and then maybe the spare tire episode.
Remember you want that spare to rupture to help the crumple when someone rear ends you.My 2019 F-150 did not have any teeth and was not impressed when I was under the truck adding Mabett underbody cover. My thoughts are to grind the teeth down to nubbings and add a slit rubber hose over them IF I attempt a full size 19" spare. Just finished installing sound deadener in the back of the cab. Additional LED bed lights next, install side decals across the lower portions of the doors, and then maybe the spare tire episode.
I was wondering about that. Thank you for asking.Remember you want that spare to rupture to help the crumple when someone rear ends you.
60psi "throwing" 40-50 lb tire towards the other vehicle!!!I was wondering about that.
I figured the engineers designed those teeth there for a reason.
And yet you take the time to read and respond to a topic that you are bored with.....Really…. These new questions that have been asked and covered over and over get old!
If there wasn’t the internet I could understand
I have an idea …. Google?
Did somebody say "throwing" ?60psi "throwing" 40-50 lb tire towards the other vehicle!!!
Actually - the idea is the Google search function on MTC throws you to the threads with actual people.And yet you take the time to read and respond to a topic that you are bored with.....
OP wanted to ask actual people, not the internet with it's boiled down answers, about a topic. That's why we're here. Novices and "experts."
Donut: Compact Spare: 155/70/17anyone get a different spare tire than the other 4
No, what it means is if you get a flat front tire on a FWD you jack up the side of the truck, place the rear tire on the front and the so called full size spare on the rear. Flats sometimes occur far from a tire shop.Yes it is a problem. So if you get a flat DO NOT USE IT. Walk to a tire store with the flat tire under your arm and buy a replacement. Joking of course. Answer this. When was your last flat tire? Mine was in 2010 and I put the spare on and drove to a tire store immediately. Had 2 tires put on, because they only had 2 alike, drove 300 miles for work. Tire store ordered 2 additional tires and a week later I had them put on.
So what am I supposed to do with AWD? Technically it's fwd the majority of the time. I'll roll the dice and put the conventional spare on which ever corner has a flat.No, what it means is if you get a flat front tire on a FWD you jack up the side of the truck, place the rear tire on the front and the so called full size spare on the rear. Flats sometimes occur far from a tire shop.
