Carlitos_92
I'd be curious to hear what size holes for the lug studs that wheel has (sized for 12mm or 14mm). A long time ago, a member related that an aftermarket steelie did not work well with the Mavericks 14mm lug nuts. I know the BAP wheels I bought that are offered for the Bronco Sports has smaller diameter holes than the OEM BAP wheels I took off my '24.
HRG
Well, I'm embarrassed to say it never even occurred to me that I should double-check the fitment beyond the hole pattern itself... I basically took Discount Tire's word for it that this was a 100% compatible part. I will check it eventually and report what I find.
wax87
Stuart
Dallas South
2004 Avalon
No, I did not try that. I seem to recall from other threads that the optional "full size" spare is still not quite up to that claim. I suspect it might be a similar diameter (to reduce differential wear) but not as wide. The location for the spare seems arbitrarily size-limited. Ford clearly does not expect you to have a flat while carrying any payload, since the tailgate blocks jack access when down. I threw a large trash bag in my tool kit so I can put the flat tire in the back seat should the bed be full. For fun, I carry a tire plug kit and a 12V compressor so I may not have to deal with the spare at all. 🤪
Yea, it is quite a bit shorter than the other four tires
Hunstville, AL
Maverick XL
Hmm, well I read through this thread, but ignored the advise. Then I had a blowout on I-75 north of Chattanooga on a 100° day in my work clothes. It wasn't too bad to change, but I don't like the spare being unmatched. You all say for sure that a matched tire will fit with a bit of mods, eh?
Carlitos_92
This is my FX4 with a "FULL full-size" tire. This is exactly the same tire that came on the other 4 alloy wheels, except on a $85 steel wheel.
Ford Maverick Spare Tire Wisdom processed-9E5A176B-3DF1-44D4-8959-478F2AA57EE5
Clearance at the back is at least 1/4".
Ford Maverick Spare Tire Wisdom processed-69EFE0D5-0877-4BE0-B16E-8F226EB5D035
Bulbous lump is stamped metal teeth; here they are hammered out of the way until I can cut them off better. If I had not messed with them already, I think there would be very little to no clearance, even if I shifted the tire against the hitch (which I really don't want to do, either). Clearance here is more or less 1/4" at the moment.
Ford Maverick Spare Tire Wisdom processed-273F462E-F09A-4D7B-AA0B-46F429D3A113
