Global Window Open Confirmed Working (Lariat Only)
entheogen
Sacramento
Any insight on if I can just swap my XLT door switches with a module for a lariat and get this feature? I assume that's all that's needed to get the four auto up/down going on a different model?
Looking like maybe it'd be these: https://parts.nplincoln.com/p/ford_...NDOW-CONTROL---DOUB/94554875/LJ6Z14529CA.html
sounds like it might add the power fold switches as well though; interested in seeing if those would be an easy enough swap as well
uraceulose
Donnie
Redding, CA
23 maverick xlt
I just bought the switch pack so will see if it works and report back
Lyonjor
Jorge
Chile
Ford Maverick Lariat
Before starting, I would like to apologize if you do not understand what I write, since I am using Google Translate to make it a little easier to read, since you speak English and, being from Chile, I speak Spanish.
Greetings colleagues, I joined the forum because I think I could give back a little help with the forscan mods. I was able to activate the "Global window close" in the DDP and PDM section, activating the "Global Window Close" section in both. I'm not very good at this but that change, added to the activation of the BdyCM module that was previously mentioned, made it possible for me to open and close the windows remotely. It should be noted that here in Chile they only sell 3 versions of the Maverick with specific equipment, in my case it is a hybrid Lariat Maverick. I don't know if this helps but I managed to get it to work this way.
I forgot to take photos to make it easier to understand.
Azmig88
Ted
2022 Ford Maverick 2.0 Lariat
Welcome to the forum, friend.
The Google translation was El Perfecto!
I have question for you. Do the Mavericks sold there have turn signals in the side mirrors?
mav_kev
PA
Mav
Newbie instructions
just did this mod. its in the bdycm (choose the second one) then under filter type global. Enable the following:
Global Open - Initial Value
Global Open - Vehicle
Global Open with Remote
Edit 2023-01-24.
To get global close enable the following:
Global close - Initial Value
Global close - Vehicle
Global close with Remote
Now for the Global windows issue:
I played with it for several hours and thought I had it more than once. Each time I tried, the "Down" feature worked, but not the "Up" feature. I tried every combination imaginable with no success.
THEN I DID THIS:
Get the GLOBAL CLOSE to work, go to module DDM and find 740-02-08 and change the third last value to this: xxxx-xxxx-x0xx (keep rest values the same!!!) then click on write
Now go to PDM module and go to value 741-02-08 change the third last value to this: xxxx-xxxx-x0xx (keep rest values the same!!!) then click on write
**note!!** you will get a Blind Spot/Cross Traffic Alert fault warning on the screen pop up, ignore this it will disappear after cycling the ignition.
To reinforce @Lyonjor 's message, I also successfully enabled global open & close yesterday following these steps, but without the number editing part mentioned by @Azmig88 . Instead, to update the settings in the DDM and PDM, under each of those modules there is a "Global close" function to enable, same as the changes made to the BdyCM outlined by @Nighowl2000 .
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
Confirmed. Just got this to work making changes in bdycm, DDM and PDM, without changing any values.
Works great on locking vehicle. All windows close.
94tbird
Ron
Treasure Island
2024 Ford Maverick Lariat
I've only had Forscan for a week but I've been digging into different settings. Today I got the global window open to work! The close doesn't seem to work. I'm on version "2.3.47 test" that I got in another thread. I probably changed more settings than I needed to but the only changes I made were in the BdyCM Module.
Awesome I had done this on my MY2005 Mustang. It was a activated feature back then, but they had to disable it because people's windows kept opening on their own, and when that happens in the rain? no Bueno. so its been deactivated on every model every year ever since to my knowledge. I mean why fix it right?
TruckPrius
Home
'23 Maverick Lariat Lux CP360 Assist
Cool, open and close working here! Go team :)
Open windows: Short press then long press (3s+) unlock on fob
Close windows: Long press (3s+) lock on fob
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Which procedure worked for you? Just got a dedicated laptop and cable and very new to FORScan.
ryan2366
Ryan
I used the procedure from @Nighowl2000 It’s simpler if you are unsure about changing hex codes.
It’s essentially enabling items that are disabled. The hex version does the same thing and will be the end result in changes to as built done by enabling.
You can set the windows to close upon locking or hold down to close. Depends on your preference (Safety of occupants or animals)
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6227
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6229
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6230
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6231
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6232
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6233
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6234
Ford Maverick Global Window Open Confirmed Working (Lariat Only) IMG_6235
Automan21
Mel
Thanks Ryan
JX77
2023 Maverick XLT Lux cp360
For those with XL/XLT, the driver and passenger door and switch pack are relatively cheap at around $30 each so under $100 for all three. But the real undertaking is the wiring and harnesses used. Check out the wiring diagram pinned in the electronics forum.
