Global Window Open Confirmed Working (Lariat Only)
Caleb Smith
Caleb
Kentucky
2022 Lariat Hybrid Oxford White
I’m gonna have to figure out how to do this stuff 😅 show me your ways!
bringjustn
Justin
SE MI
2017 Cruze, 22 Mav
What specifically did you get to work? Up and down?
So far just down. I haven't had a chance to play with it again to see if I can get to go back up. My guess is it is some combination of enabled and disabled modules. I wonder what are enabled on a car that has the option from the factory.
crashdumie
unknown
Ocala. FL
2023 Ford Maverick Lariat
anyone figure out global close yet?
crashdumie
unknown
Ocala. FL
Confirmed working on another hybrid lariat lux. Took a few tries to get it to work.
i was looking at the IPC module listings, and noticed Global open and Global Close listed in there. do you have to change that as well? could that get the Global close to work?
i am new to forscan, not sure what has been attempted already.
Gullzway
OK
1968 Ford Mustang Fastback
I tried that and it didn't work.
crashdumie
unknown
Ocala. FL
okay, this forscan stuff it confusing, half the thing i know are turned on show as Disabled on there but yet it still works. makes me confused on what to touch and not touch
charlierosario
Carlos
Argentina, Rosario, Santa Fe
Ford Maverick Lariat Fx4
Confirmed working ok on lariat fx4, only global windows open.
but not global windows close.
Investigating changes in the bdyCM module as built settings after changing parameters in the easy mode (BdyCM module configuration) in forscan related to global windows close and open, I came to the conclusion in my case (I do not know if it is the same in all units) that the memory addresses that are modified with changes showed in this post here are these, but I don't know what value I should enter for enable global windows closing. If anyone know the value of the adress i try it and report here.
addresses from BdyCM as built.
7260607 03E0 F804 A0B9 | ORIGINAL
F80C A0C1 | ONLY OPEN (this value working fine on lariat)
F81C A0D1 | BOTH OPEN AND CLOSE (this value is not working)
7261301 0078 0080 39 | ORIGINAL
0180 3A | ONLY OPEN (this value working fine on lariat)
1180 4A | BOTH OPEN AND CLOSE (this value is not working)
7260606 2113 0001 F05E | ORIGINAL
0043 F0A0 | OPEN AND CLOSE
22 Maverick Lariat Luxury Carbonized Gray
I also tried and the open works, but the close does not. Still nice that I can open them on the typical hot day here in FL.
crashdumie
unknown
Ocala. FL
I agree, this FL heat can get bad. it is nice to open the windows and let the car vent out for a few minutes before getting out of work.
Just set those values for Global Window Close and can confirm they work. To save you some searching those As-Built fields are in the DDM (Driver's Door Module) and PDM (Passenger's "). Also don't be surprised when you write to those modules if you have CP360 you'll get a Blind Spot/Cross Traffic Alert fault warning on the IPC that'll disappear after ignition cycling.
