Global Window Open Confirmed Working (Lariat Only)
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
Is it possible to have Ford dealership enable all windows to go down with the remote?
If you have the correct model with one touch up and down switches you can enable yourself with Forscan. It would likely be cheaper to purchase the cable and licence for Forscan than pay a dealership.
Not sure if a dealership would do it or not.
Montana
I used the procedure from @Nighowl2000 It’s simpler if you are unsure about changing hex codes.
It’s essentially enabling items that are disabled. The hex version does the same thing and will be the end result in changes to as built done by enabling.
You can set the windows to close upon locking or hold down to close. Depends on your preference (Safety of occupants or animals)
Is there a setting in there to disable the auto down when it detects force against the window? My deflectors are constantly causing the window to roll down.
Example: I crack the window but go to roll it up and it detects the small amount of flex from the deflector pushing against the window, so instead of going up it goes all the way down. I can't stop it until it's more than half way down and if I try to roll the window back up without it going all the way down first, then the one touch up is disabled and I have to hold the switch.
Only the drivers side does this but occasionally in the past the passenger side does too. Totally random and usually it's because of the change in temperatures, but after I wash the truck if I crack the window I don't want it rolling down all the way. Very annoying.
I have searched in Forscan and have no idea where to even begin but I didn't see anything in the settings you found to disable this. I wonder if it's just a "feature" in the motor itself?
ryan2366
Ryan
I have the EGR in channel vent visors and occasionally have this issue.
I sometimes have to pull the visors outwards to give the window a little more space. Then reset the window limiter
Montana
I'll give it a shot.
Those deflectors didn't come with enough adhesive on the fronts so I added my own, but the part I can see that's causing the issue is on the part I didn't add any on... of course. So I might just redo the adhesive across the entire thing. Without it I got tons of wind noise and even more flex. The issue was much worse without the adhesive. First set I've ever owned that didn't have adhesive on the fronts.
Anyways, thanks for sharing. Didn't know this existed.
ryan2366
Ryan
Yes, my front ones came with no adhesive at all. I recently added adhesive but occasionally my window gets stuck and I get A DTC for DDM (drivers door module) which I need to reset. Check for that in the DTC’s with Forscan as well.
OleKennyRoy
Kenny
Maverick Lariat
So, just did this today. I changed DDM and PDM (not As Built) Global Window Close to "Enable"
OleKennyRoy
Kenny
Maverick Lariat
Anyone have luck controlling the sliding rear window?
Raphaelfns
Raphael
Brazil
2023 Ford Maverick Lariat
Hello,
I tried everything that was posted here before, and still can´t make it to work. Mine is a 2023 Lariat, with one touch up and down for all windows.
Any help, appreciated
Thanks!
Raphaelfns
Raphael
Brazil
Also.., now, I believe that the “pinch protection” on the driver’s side is on, and everytime it goes up, it comes back down instantly.
How to go back to factory using asbuilt mode?
Thanks again
Why would anybody want to do that? Just press the button on the door.
Here in Nevada when it is 112°f in the shade. The interior can reach 127°+
It is kind of nice to open the windows ahead of time and cool things down to 110°. 🥵
Just because I feel it would be nice and convenient for me.
I can understand why this would not be important to someone from northern Canada.
Taking care and staying cool as possible.
GB
A Mind is like a a parachute, works best when it's open. 🪂
gstevewa
Ohio
2025 maverick lariat
Hi. I have a 25 lariat and this is disabled. I seen on YouTube you also have to change the apim to open and close. Did you not have to do that? Never used forscan b4 and wanna be sure b4 I do it. Thanks
ryan2366
Ryan
I honestly don’t remember. I think doing APIM just gives you a button on the infotainment screen to turn global on and off.
Either way it won’t hurt for you to add it there as well.
ryan2366
Ryan
With regards to the pinch protection and in channel visors. I also used to run into the window not having enough space in the channel and going down.
Sometimes it deactivates the one touch feature.
I found a bit of silicone spray reduced resistance and allowed the window to close.
If the one touch does stop working. You can also reset it by putting the window down and holding for 2 seconds, then up and hold for 2 seconds.
Provided you have removed the resistance it should return to normal operation.
gstevewa
Ohio
Well thank you for the response. Im new here and guess I didnt realize it's been over 2 years since your post. You've been a big help!
