Unlock all doors with FOB single button press mod confirmed working (via FORScan)
Maverick2022XL
name
hinterlands
This mod applies to all models that use a key fob to lock and unlock the doors.
By default to unlock all doors requires 2 button presses, 1 to unlock the front doors then again to unlock the back doors. This mod will unlock both the front and back doors with a single key press.
Default - 2 button press front then back
BCM
726-03-07
8xxx xxxx xxxx
1 button press front and back
BCM
726-03-07
0xxx xxxx xxxx
You'll get a checksum error when you change the value but forscan should correct it when it writes the new value. That's it.
jsus
2022 Ford Escape Hybrid AWD
This doesn't require FORScan mods. There's a button sequence that will switch between the two. Don't have it right in front of me but you just need the fob for it.
'Two-stage unlocking' Ford calls the setting.
The owner's manual calls out instructions for doing it via the fob but the mention of the door sensor makes it sound like it may be Lariat-applicable.
Reprogramming the Unlocking Function
You can enable two-stage unlocking function allowing you to unlock only the driver door when you touch the unlock sensor. Press and hold both the lock and unlock buttons on the remote control for four seconds to disable or enable two-stage unlocking.
Maverick2022XL
name
hinterlands
There is more than one way to get to the same result then.
MikeyG
phila
I can unlock mine with one button press. No FORScan required. It can be programmed in the settings.
Did you do this by holding the lock and unlock together for 4 seconds like stated above? Also do you have a lariat or a different trim?
MikeyG
phila
XLT
I did it with the settings in the instrument cluster display.
Ok thanks. Is there a how to in the owners manual? My maverick should be here next week.
DannyP
Danny
Kentucky
2004 F150, 2017 Escape SE, 1929 Model A Coupe
Maybe, I don’t know.
Here is what I did:
•Go to vehicle settings
•Locks
•Remote unlock
•select “All Doors”
The pictures got out of order when unattached them but you should be able to get the idea.
Ford Maverick Unlock all doors with FOB single button press mod confirmed working (via FORScan) 98724B78-FA22-42F8-A3CB-8086A7B3EA42
Ford Maverick Unlock all doors with FOB single button press mod confirmed working (via FORScan) 4A485B55-15F1-4568-86C3-114680D1DCAE
Ford Maverick Unlock all doors with FOB single button press mod confirmed working (via FORScan) 1A286834-46D2-49D1-97E1-7BE0097AA8AA
Ford Maverick Unlock all doors with FOB single button press mod confirmed working (via FORScan) 443B682A-3EEC-4C6B-921F-D43FB0275EAE
Ford Maverick Unlock all doors with FOB single button press mod confirmed working (via FORScan) DF603A42-A189-4514-A006-B038AF2402EB
MikeyG
phila
Here is what I did:
•Locks
•Remote unlock
•select “All Doors”
Awesome. Thank you!
Brent
Awesome. Thank you!
I gotta admit I'm an idiot. I was all cocky and was convinced I had been through that menu a million times. Well I had but then I realized that I was only seeing wipers as a setting because I didn't SCROLL UP. Face palm on my part. Thanks for the help
