Maverick2022XL
name
hinterlands
Can you disable "normal" mode?
You know lots of people want Eco every day, and for Hybrids, Slippery mode is significantly better for easy MPG boost.
I drive in Slippery EVERY DAY but have to push the button 3x every key start.
No as far as I know. But to be fair I've never actually tried to do so. I will try it and report back.
Maverick2022XL
name
hinterlands
The answer is you can but it gets overridden elsewhere and is still active.
GPSMan
Many
Thanks for checking.
I guess there's always the circuit add-on build to just actually press the button 3 times, but automatically Or now, I'm just in a habit of doing it, like putting on a seat belt the urgency of a "mod" gets less and less.
Appreciate you looking into it.
Kenny
Kenny
2022 Maverick XLT 2.0 Ecoboost with AWD, Tow Pkg
Several months ago I added Eco and Sport modes to my 2.0 AWD FX4 with 4K Tow using Forscan. Yesterday all of a sudden Eco and Sport modes disappeared and I'm back to the factory only modes. Any idea why that is? Has anyone else experienced this?
pa-outdoorsman
PA
2022 Maverick XLT, EB, LUX, FX4, 4K, Cactus Gray
It’s possible Ford pushed out an automatic over the air update that reset your modules but you ought to be able to reactivate them again the same as you did before.
Maverick2022XL
name
hinterlands
That or if he had his ABS module reprogrammed for the trailer brake light recall. That had knocked all my custom ABS settings out when they did mine.
Kenny
Kenny
That's it! I just got the recall done right before it happened. Thank you.
Big Kahuna
WA
I've seen quite a few posts on here about using ForScan to do this modification but I'm wondering if it's possible for a dealer to easily do the same thing via their computer systems?
They probably could but unless you know a tech and/or the service manager pretty well I doubt they're going to want to make arbitrary, not Ford approved code changes you found on the internet.
Gpp
Gil
Sanford nc
2022 ford maverick
The ford technicians can make all kinda changes for
diagnostic purposes only but have to reset everything back like it was when done.and yes it helps to be a good friend of the technician.😉
Kenny
Kenny
I just had the tail light recall software update performed by my dealer. I notice it wiped out my Sport and Eco modes (I have the FX4 with 4K) but kept all of my other Forscan changes (turning off various chimes, disabled panic alarm on FOB). So they must be ok with owners doing some Forscan mods, but not adding those modes.
That's because the changes for enabling drive modes is done in the ABS module. The trailer brake recall reprogrammed the ABS module and likely would have included resetting the configuration values in it to as-built, but not have affected the other modules such as the ones you mention being stored in the BCM.
felsf50
Scott
NEPA
Should the drive modes be enabled in the ABS "as built" line or just the ABS line? In the non "as built" selection, you must DISABLE ABS?? Is this antilock braking being disabled?
Kenny
Kenny
No.
