Global Window Open Confirmed Working (Lariat Only)
Buzz_Bronski
New Jersey
2022 Maverick XLT AWD FX4
I do not believe so, just on the driver's window as far as I'm aware. Was hoping to at least have the ability to control my window. But it seems none of them work with this.
TrippMe
Tripp
I just changed my coding to match what is shown by OP and it doesn't work on my car with my keyfob.
Any thoughts or suggestions?
oreomuffin
oreomuffin
CaptainK
Minnesota
I've updated the title. I believe you must have auto up/down on all windows for this to work. The lariat is the only one with that option. Sorry to get hopes up for our XLT friends...
Different car, but see the second post:
https://forscan.org/forum/viewtopic.php?t=9136
FakeCowboy
Mid Atlantic
2016 Subaru WRX
I think the 4 windows having auto up and down has it's own separate control module which would explain why this would be programmed in forscan. Pretty sure that's why it's only possible on the Lariat
TrippMe
Tripp
That would explain it. I do have auto down on driver side only.
CoryDallas8123
Cory
Dallas, TX
Audi A4, Chevy Chevelle SS, 2022 Maverick XLT
CoryDallas8123
Cory
Dallas, TX
I'm pretty sure the Lariat has a different wiring harness for the windows with a separate control module that the XLT and XL don't have
Nooooooooo!
This is the only mod I really wanted. But oh well.
jsus
2022 Ford Escape Hybrid AWD
Yes, this feature is going to use the same hardware capability that auto up/down would on the control panel on the door. So if your Maverick doesn't have that, then you can't do this either. The window regulators in the doors are different so they can be programmed with calibration for the fully open and closed positions. That's how it knows when to stop. If you don't have those parts, it won't work.
FakeCowboy
Mid Atlantic
2016 Subaru WRX
Nooooooooo!
yeah, it's not even like you can just switch out the window controls from a model with auto up down on all 4, you need the harnesses which have extra wires in them as well as the control module.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
I've only had Forscan for a week but I've been digging into different settings. Today I got the global window open to work! The close doesn't seem to work. I'm on version "2.3.47 test" that I got in another thread. I probably changed more settings than I needed to but the only changes I made were in the BdyCM Module.
Newbie instructions
just did this mod. its in the bdycm (choose the second one) then under filter type global. Enable the following:
Global Open - Initial Value
Global Open - Vehicle
Global Open with Remote
Edit 2023-01-24.
To get global close enable the following:
Global close - Initial Value
Global close - Vehicle
Global close with Remote
Updated Feb 18 2023
Get the GLOBAL CLOSE to work, go to module DDM and find 740-02-08 and change the third last value to this: xxxx-xxxx-x0xx (keep rest values the same!!!) then click on write
Now go to PDM module and go to value 741-02-08 change the third last value to this: xxxx-xxxx-x0xx (keep rest values the same!!!) then click on write
**note!!** you will get a Blind Spot/Cross Traffic Alert fault warning on the screen pop up, ignore this it will disappear after cycling the ignition.
To test opening the windows:
press unlock x2 and hold button on second press on keyfob
To test closing the windows:
press lock x2 and hold button on second press on keyfob
oreomuffin
oreomuffin
CaptainK
Minnesota
Newbie instructions
Thanks!
Did you attempt global close? Any luck?
Nighowl2000
Roy
Ottawa
Works now
06Warrior
Person
19' HD Road Glide, 22’ Sporster S
Thanks!
I don’t think it can be enabled for safety reasons such as closing on a child or pets head etc.
Nighowl2000
Roy
Ottawa
Works now
