Oil Changes - Dealer or DIY
DCP
Tennessee
2014 Flex, 2018 Escape, 2023 Maverick XLT Hybrid
Which Fumoto valve did you purchase? Please provide part number. I've been curious which valve fits best.
The drain valve is the F137N and the adapter is the ADP-137. You will need the adapter because of the way the oil pan is shaped around the drain opening.
Randy H.
Randy
Bristol, CT
Maverick & Civic
Why not use the standard F137 or F137S with the adapter? This combo would be a bit shorter overall.. please advise.
Randy H.
Randy
Bristol, CT
Maverick & Civic
Also per the Fumoto website both the ADP-137 and ADP-107 are 1/2” adapters for M12 X 1.75 valves. And the F137 & F107 are both M12x1.75 valves. What’s different/why different part numbers?
Caper
Nova Scotia
Maverick FX4
I have always done my own oil changes. My first oil change was offered "free" at the dealer so I took advantage of this. When I got home I looked under to see if everything looked right. They left off 1/2 the bolts that attach the protective plate (off-road package). They also removed the rear plate which wasn't required. So back to the dealer....wasted a whole morning.
Now I have a second "free" oil change offer for my trouble. Don't assume your dealer will do the best job...as someone said previously I don't think their A mechanic is doing oil changes.
MiMav
'23 EB FX4 4k Maverick, '14 Escape
That's my experience too from multiple dealer's oil change places. They especially like leaving out screws and bolts. I believe that most who think they have great service don't check the work.
SLINGSHOT
Charles
NE Iowa
2017 RAV4
ALL brands have the same problem. I had a "free" oil change on a new car. I foolishly waited until I got home to check it (never again). It was WAY overfilled. Back to the shop. As I was explaining to the guy at the desk, a mechanic overheard and said, "Smith AGAIN?" The desk guy said, "YES". Mechanic walked away shaking his head. "Smith" had a reputation of doing this. He just dumped in oil until he figured it was "close enough". They offered me 5 free oil changes. Probably with the same dummy who screwed it up the first time!!! I said, "No," and never went back. Even switched brands.
We drop off our multi-thousand dollar machines to be serviced by a high school drop out.
KeinoDoggy
Elliot
Ohio
2022 Maverick Hybrid and Outback
"They left off 1/2 the bolts that attach the protective plate". Which is exactly what I thought might happen and part of my reasoning for doing it myself.
DCP
Tennessee
The adapter is needed either way. You can use either valve - the F137N has an extended nipple to allow for the easy attachment of a drain tube. The length does not appear to be a factor as the installation is nearly horizontal. It won't be a make or break deal with either configuration. I connect a piece of tubing and drain the old oil straight into an old 5-qt. container and then drop it by my local parts store for recycling.
DCP
Tennessee
This is the setup you'll get with the F137N and ADP-137. They fit and work well on the Hybrid 2.5L engine. The other options are different types of valves that should work as well. These work great for me.
Ford Maverick Oil Changes - Dealer or DIY IMG_1825
DCP
Tennessee
As a bonus, when the dealer cut the holes in the cover for the fire hazard recall, they cut out a spot right below the oil drain port. Now I just connect a drain tube to my Fumoto valve and drain the oil. Then I remove the front eight or ten T27 screws and lower the front of the cover enough to change my filter. I don't fully remove the cover anymore.
BDennis
Bruce
So Cal
Just be careful with the oil you choose to use, Ford has specific oil spec requirements for the Ecoboost that many oils including Pennzoil Platinum, Ultra Platinum and standard Mobil 1 don't meet (yet). The oil spec they require is formulated to be less vulnerable to low speed preignition and to promote better wear of timing chain guides, both of which have been problems for ecoboost motors. Using non spec oil could present a problem in the event of a warranty claim.
Directly from the owners manual and this is the only requirement when changing oil, and it does not require WSS. “We recommend Motorcraft® motor oil for your vehicle. If Motorcraft® oil is not available, use motor oils of the recommended viscosity grade that display the API Certification Mark for gasoline engines.” BTW, Mobil 1 5/30 is WSS.
Ford Maverick Oil Changes - Dealer or DIY 545323F6-E258-4890-BB03-DD89AA406DDB
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
" If I was to buy my own oil and filter it would be over $115 CAD "
II think you need to find a better place to buy your oil and filters. Mobil 1 is currently on sale at Costco for $34 USD for 6 quarts
It's a Canada vs US thing. When it comes to that kind of stuff it just costs double to buy it yourself here, and has been for years. That and it's a pain to find anywhere that will take used automotive oil too. I'd have to drive for an hour or more to get to place that does it and I live in a major metropolitan area. In the end it's cheaper to have the dealer do it.
NoVaJimmy
KCMO
Lexus GX 460
That's great but I'm just going to leave this here, also directly from the manual. Pay attention to the use of the word "Specification": As my commander use to say in the Army, "Do whatever your career (warranty) can withstand"
Ford Maverick Oil Changes - Dealer or DIY 2.0 Oil Reqs
Dad
Owners manual. Access online. It's available even if you don't own a Maverick.
DIY or dealer service is personal choice. I prefer dealer maintenance during warranty to maintain a service record and establish relationship with dealer. After that I do it myself.
If choosing DIY maintain record of receipts for oil and parts and document the oil changes.
I think this is smart. I don't want to give Ford any reason to void a warranty.
TheWizziard
Texas-RGV
2023 Maverick XLT Oxford White
While we are so similar I have to remember that we are also different.
While we are far from perfect, we can return our used oil to most of the stores that sell it. At least around here where I live.
