DIY Oil Changes? Accessing oil filter?
Norm
Massachusetts
None
Why would you want to change your own oil in a new vehicle? My Ford Quick Lane charges less than I would pay for 6 qts of oil & filter. They also do multipoint inspection. Changing your own oil you must set up & drive onto ramps, then crawl under it & then you have to find a place to dispose of used oil & cleanup your tools. I can understand now trusting the corner quicky lube, but you should trust your Ford dealer.
Because they hire squids from the local high school and pay them five dollars an hour and they put the covers back on bubble gum. It’s your choice.
Old_Norm
Norm
Columbus Ohio
2023 Mustang Mach E 2023 Maverick Lariat
Oil change (Hybrid) at the 1:15 mark.
Cidecar2
Spokane, WA
2024 Maverick XLT Hybrid (in transit)
I like to change my own oil. Has anyone observed or asked a Ford rep about the ability to access the oil filter? On the Ranger I have heard that one of the front wheel well liners must be partially removed in order to access the oil filter. I hope that this is not true on the Maverick.
First change on my 2024 xlt hybrid at 3,300 miles (1,800 highway) Ford recommended filter and Valvoline ultimate 0-20 full synthetic oil Meets/exceeds Ford Spec. Many Torx #30 for engine shield (it's no skidplate just keeps dirt off). Really tiny oil filter which the factory put on way too tight, had to use my claw style filter wrench to get it off. The recommended Ford filter is twice the capacity at least and has gotten good reviews. I normally used Mobil 1 filters but decided to give the factory one a go at least for the warranty period. Always prefill the filter and it's a verticle mount, no spillage. Very easy.
Mdmac
Kansas
2023 Maverick XLT
Hello, just changed my own Oil and Filter. You have to remove the big splash shield under the motor. I believe 8 or 9 Torx head screws. Very easy. Some people in the club have cut an access hole also. Good Luck
My first oil change was semi synthetic, it was a free oil change. I will pay for full synthetic with future changes. I have no intention of ever changing my own oil again, I can get down under the vehicle, but I cannot get back up without assistance.
To help getting up without assistance. While sitting in recliner or couch or whatever lift feet either one at a time or both together and hold them with knees straight but not locked pointing toes toward tv then towards ceiling during commercials. Also bend knees and straighten them without touching feet to floor. This will also build cheek muscles so you can handle sitting for a longer time in your maverick. If you watch tennis you can point your big toe of each foot and follow the ball! If you watch wheel of fortune toe point to the prize wedge of your choice.
CurtisB
2023 Maverick XLT Hybrid
You don't realize the importance of your core muscles until you become a "seasoned" person. Abs and lower back become the main focal point of existance and comfort.
Mr Pibb
Vegas
2024 Lariat
Got a rival skidplate on order that has access panels for filter and drain plug. Whenever I do my first change I'll definitely pop a fumoto on there to make it even easier
Tom 71 Maverick 24
Northeast Ohio
The first oil change is always a little tougher - the factory LOVES to put that filter on super tight. And from a video or two I've seen, they used Loctite on the bolts for the skid plate on the FX4 they serviced.
Still, once that first one is out of the way, I don't see an issue with changing it yourself.
Mdmac
Kansas
2023 Maverick XLT
Hello, I used Mobil 1 5-30 synthetic Oil and a Wix Oil Filter. I personally like Wix Filters. Got everything from O'Reilly. Yes, always fill my filter with Oil before I install it
Old_Norm
Norm
Columbus Ohio
Just FYI, the Fumoto valve makes the oil flow very slowly.
Mr Pibb
Vegas
2024 Lariat
That isn't too much of a problem for me, my current car I use a pump to get it out the dipstick hole since the filter is also on top.
