What MPG are you getting with the AWD 2.0 Maverick
imboden013
West Memphis AR
2024 & 2025 Mavericks
2022 MAVERICK AWD trip to the farm 218.2 miles about 20 of it in town and on farm. 6 gals regular 87 octane. That comes out to 36.3mpg
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick 2C06A41D-6B61-4A03-B330-4EE7696DDB62
PlantMan
Berwyn Heights, Maryland
2017 F-250 4WD crew 8' bed; 2022 Maverick XL AWD
I'm getting slightly more than 22 mpg from my stock EB AWD Maverick. My driving is probably the worst possible case for mileage, short of towing. 99% is 30-45 mph, traffic light to traffic light, suburb driving.
imboden013
West Memphis AR
Taken 2 trips since purchasing used 22 Lariat AWD. 1st trip 499.5 miles/ 14.7 gal @60-65mph that’s 34mpg 2nd trip 218.2 miles/6gal @55-65 mph comes to 36.3 mpg. I use cruise control almost 100% of time
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick 49491BBA-D0F2-4CD0-ADEC-00E1C437AD07
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick C69D179C-2A5A-45DA-8522-ED2FCB0C5139
imboden013
West Memphis AR
Pictures posted in reverse order of description. Mpg stated is hand calculated but real close to Mavericks trip computer. I checked odometer to mile markers on 10 mile stretch of road and it’s within 1-2%. Used 87 octane regular with 10% ethanol.
imboden013
West Memphis AR
Just got home from my 3rd trip in my Maverick AWD. Purchase used with 8900 miles so it’s already broke in. First trip 499.5 miles 14.7 gallons 34mpg. 2nd trip 218.2 miles 6 gallons 36.3 mpg. 3rd trip 439.6 miles 12.4 gallons 35.4 mpg. All hand calculated each one was within +or - 0.5mpg of truck computer. First two trips was half and half flat level terrain and up and down hills of 600-700 ft elevation change. 3rd trip was 40% level terrain 50% up and down hills with elevation changes of 1000 ft in Ozarks plus 10% of stop and go traffic in towns and numerous stops at flea markets.
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick F16ED2D2-396B-4E17-BA84-BFB9D7CD1E36
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick 182D9115-0351-475D-BE50-0821E57357D4
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick 0413119F-8478-4360-8264-3AF037E49F21
Dignam
Madison, WI
'25 Maverick Lariat
I have probably the least fuel efficient configuration. In my only significant trip (250 miles one way), I got about 28.5 mpg with cruise around 72mph average. This was with a direct headwind of 15-20 mph though.
I imagine in the summer without the nasty wind I'd be pushing 30 mpg no problem.
imboden013
West Memphis AR
I drive about 65 and with no head wind I get in mid 30s using cruise control.
Sleeper 7
Steven
NH
18 Fusion 14 Ram Dump 23 Maverick XL
What rpm are you guys running at 65mph? How about rpm with 4k vs standard EB at 65mph?
imboden013
West Memphis AR
Seems my AWD lariat is turning about 1600-1700 at 65. The key to great mpg is use that cruise control as much as possible, I use mine to speed up a slow down. I’ll bump it up a couple taps at a time. Example going from 45-55, I’ll tap it 2 times let it get to 47 then tap a couple times again to get to 49 and son if you do that rather than bump up all way to 55 or use foot so transmission doesn’t kick down to lower gear as often. Also when stopping start early by coasting a bit. And I don’t use eco mode as it seems to burn a little more gas than normal mode. Main thing is act like there’s an egg under the gas pedal. I have seen 42 mpg on an 60 mile trip and that’s with an AWD.
Paulyz
Paul
Forestville, WI
www.churchbelltoweradventure-suspense.com
28.4 driving mildly aggressive on the interstate. Can't wait to see it after it breaks in.
My mechanic said not to drive aggressively until engine breaks in. The piston rings need to set. I also asked him about best oil to use. Ford recommends synthetic blend & he agreed, but said after about 10,000 miles he'd switch to full synthetic.
desmobob
Upstate NY
2022 XLT EcoBoost tow package, 1995 Ducati 900SS SP, 2025 CF Moto CF500
I forgot to check the specifics, but here's a shot of my EB 4K on the highway today. This is with winter blend gasoline, too. The MPG should increase by about 10% when the warm weather formula hits the pumps. I love that it gets better mileage than my Subaru Forester did, while also having a LOT better performance. (y)
Looks like about 1800 RPM at about 68-69 MPH...
Ford Maverick What MPG are you getting with the AWD 2.0 Maverick DSCF0528_02-10-23_1197DSCF0528
Sleeper 7
Steven
NH
And your 4k maybe 300 rpm higher than a non 4k. As long as it stays below 2k rpm mileage should be decent
MrCigar
2022 Maverick XLT EB FX4 Cactus Grey
2.0 XLT FX4, just turned 4500 miles. It's my commuter so same route daily, eight miles to fwy on city streets, 30 miles freeway to work. Started out averaging 27/28 mpg. About the time I hit 3k it started improving, I am sitting currently at a steady 30 mpg each tank, 70-72 mph on fwy each day.
