Hitch receiver, come on already
Area51BS
Ron
Could you use the 12 volt power option near tailgate?
finallygotamaverick
Huntsville Al.
22 maverick
Ok, Was able to do the measurement. The rectangular tube measures 3-5/16" X 2". Reality is the crash bar is the exact size of the hitch without the dropdown receiver. It would be super easy for a welder to just add a receiver to the crash bar!
I did just that. Went to Tractor Supply and bought a receiver and with a couple plates cut and some welding had a hitch. Cost about $50 in supplies.
Ford Maverick Hitch receiver, come on already thumbnail (8)
ShadowBlack XL440
Robert
Northern Ohio
Thanks for the measurements. You are on track to where I am headed. My plan is to weld on the receiver like one you can buy for a Jeep JK/JU for 50.00. I may have to modify the width but I am sure there are some applications that are already 2.00'' wide. Need to do some more research to find a direct fit.
Ford Maverick Hitch receiver, come on already 1646139577451
ShadowBlack XL440
Robert
Northern Ohio
I ordered the E- Trailor kit for the Bronco Sport. Easy install but you have to change the wires going to the new module. You also have to run a wire to the + post on the battery. The splitters pug right up to the taillights. You have to cut the red and brown wires going to the new module. Then tie the red to brown and the brown to the red. This worked for me, but I am not liable for your install. You do not have to splice into the truck wiring harness. Here you can see the splitter plugged into the taillights and the red and brown wires going to the new module redone. Hope this works for you. It did for me.
Good job making that work. Did you have to do the wire flip on both sides or just the one? Was it the brake light and turn signal that was reversed?
Adospeed
Ado
Colorado
Hybrid in Shadow Black
@finallygotamaverick Can you clarify for @ShadowBlack XL440 and I what the brown and red wire are (blinker or brake, etc)? And how did you figure that out, with a voltage tester or a wiring diagram? Thx. My Ford Escape etrailer kit (# TE54FR ) should show up in a day or so.
finallygotamaverick
Huntsville Al.
22 maverick
Hey Ado. I used a meter and 50 years experience to figure it out. Now I used the Bronco Sport one so it may be different than the Escape.
skadizzle
Orlando, Florida
2023 Ford Maverick Lariat BAP
If we bought a Lariat Lux it says it comes with the class 4 hitch. If so, all I need to buy is the ball, correct?
Johnkn
MD
You will need a Ball mount and ball.
Adospeed
Ado
Colorado
Im about to order it, just trying to decide the Escape or the Bronco Sport......haha
****Updated**** Just ordered the T Connector wiring harness for the 2022 Ford Escape: https://www.etrailer.com/Custom-Fit...Escape/2022/TE54FR.html?VehicleID=20225001399
If anyone one else is gonna try this, order the Bronco Sport one so we can get a cross reference :)
@RonR1959 @finallygotamaverick Sadly, I can confirm that the 2022 Ford Escape kit will not work. The male-female connectors are slightly different. Next step, either the Bronco Sport one that @finallygotamaverick made work, and checking with the kit manufacturers on ETAs for Mav specific.
We're making this easier for all others in the same boat. Thx again for sharing your efforts.
Deleted member 5597
Guest
I ordered the Curt wiring harness for the Bronco Sport. It just came in Friday. I’m taking it to get it installed Wednesday morning. Hopefully it works.
Adospeed
Ado
Colorado
Sweet Ron, please post the outcome!
Mymaverick2021
Steveo
Hilo Hi
From what I have read so far, It looks like the E-Trailer Harness may be the only option!
Somebody said the Escape harness won't work but the Bronco Sport will. Can't confirm that as fact but it's a good place to start
Mymaverick2021
Steveo
Hilo Hi
