Flat towing the Maverick?
GPSMan
Many
There seems to be agreement you CAN flat tow a hybrid Maverick. Not much talk about how and why this is possible.
I owned a First Generation (first ever) Ford Escape Hybrid. December 2004 build on a 2005 Model year.
It could not be towed with wheels down. Main reason; there was no clutch, no movable gears, no mechanical neutral. The gears in an eCVT are always in mesh.
The hybrid eCVT transmission is a planetary gear set with three parts. You have a traction motor, a smaller generator motor, and a gasoline engine. Any time the wheels are moving; at least 2 out of 3 other components need to be moving. When the engine is off, the Motor and Generator MUST be spinning. (And they spin in opposite directions.)
For car washes, and pushing short distances by hand; there was only what I call "pretend neutral". In "pretend neutral" the pretend gear selector in N position only meant no electrical power would be sent to either the traction motor or generator. During the car wash; the motor and generator would spin, but ovbiously slowly, and obviously for short duration. Thus no harm done.
I'm skeptical without engineering documentation that there is a mechanical neutral in the Maverick. But it is 15 years newer, and anything is possible.
The "must run" every 6 hours leads me to believe your motor and generator ARE spinning while in motion; just freewheeling. Also the run every six hours is probably to charge the HV traction battery, NOT the 12 volt battery. So those of you with the 12 volt line from the RV are not excused from this requirement. I personally would use a dolly. Get those front wheels off the ground. More work; but way safer. ESPECIALLY if you do a lot of miles RV with a toad. Kind of a paradox. For occasional use; I'd say, go ahead and flat tow. For frequent use; use a dolly. However the frequent user is the user who wants to flat tow (but probably shouldn't).
Also the 70 mph limit should not be taken lightly. This is also evidence your traction motor and generator are spinning while being towed. With the engine off, there is a fixed gear ratio between the wheels and the electric motors. Above 70 mph the rpms of the smaller generator will probably be above design limits. In the 3 part planetary gear set, which is an engineering marvel, as the gas engine speeds up; the generator can slow down, and this is how you get infinite gear ratios in an eCVT. But with only 2 parts active, you have a fixed gear ratio.
None of this matters if you guys find there is a mechanical disconnect, a mechanical neutral. The first few generations of hybrids didn't, so I'm very curious about this subject.
Cruzer01
2022 Ford Maverick XL
GPS Man, looks like this topic will be discussed and you might be able to get answers to your specific questions here.
https://www.mavericktruckclub.com/f...-to-with-your-maverick-today.4404/post-360163
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Agreement because Ford tested it, and says you can in the instruction manual. The rest of your post is Guesses, based on a Different vehicle.
There are other threads on this, and Mav owners who are already doing it.
GPSMan
Many
Linda B
Linda
Ford Maverick XLT Lux!!!, E450 Lazy Daze Motorhome
GPSMan
Many
Ya, I noticed that about a minute later. Inverse topic, but maybe there will be some crossover? 🙏🏻
BDennis
Bruce
So Cal
The current version of the Ford Escape Hybrid has been flat towed for a couple of years now. I have flat towed my Maverick for 2,700 miles in 21 days, no issues.
DiverUtah
Layton, ut
2023 Maverick Lariat Hybrid Cyber Orange
Does anyone know if the 2023 hybrid has the same eCVT
pdesroches
Patrick
Montreal
Hybrid Maverick 2023 XLT
Thank you GREG -That is great to hear!
I was concerned that the high voltage cables and/or the brake booster might get in the way. - but I am only able to guess d/t not having truck to look at.
Which towbar are you using?
I might hit you up for some photos of your install after I get my Mav. Happy trails and hope you get your baseplate soon. 👍 :D
Hi, Do you have a picture on where do you put your wireless tail light on the maverick ?
Thanks
KathyG
Kathy
Northern CA
2023 Maverick Hybrid XLT
Thanks
It is not wireless, it is a diode wiring kit you install that allows you to use your factory lights for rear running lights, turn signals and brake lights.
Go to etrailer web site and watch their install video for diode wiring for Maverick.
I just finally got my Maverick and all my parts to set it up for flat towing - I have not done the install yet.
However, I did do this on our previous TOAD (2006 Honda CRV), using etrailer videos and the written instructions I did diode wiring kit, base plate, and supplemmental braking system. It tajes a little time, but is very doable by anyone with tools and time.
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
It’s a wonderful thing to see your Mav copy the motorhome turn and brake signals. With LasFits installed, I doubt anyone could allege they couldn’t see I was braking and/or ready to turn.
GPSMan
Many
My hypothesis from August was confirmed.
When you tow with the front wheels down, the motor and generator spin in equal and opposite directions.
The speed is 125 rpm per MPH with stock tires.
The tow speed should be limited to 70 mph. 70 mph x 125 rpm/mph = 8750 rpm your motors are spinning, in freewheel so there is little heat or resistance generated, but there is still mechanical wear.
You are putting miles on the transmission even if not on the odometer.
Also it looks like the transmission oil is pumped via a connecting shaft attached to the gas engine. Another reason, and maybe a bigger reason than battery recharging to start the gas engine regularly is to circulate the transmission oil.
I'm not doing it now, but if opportunity knocks in the future, I'll be using a dolly for my own piece of mind. I understand backing is between difficult and impossible but hey, I'll feel way more comfortable about the truck being safe since it is my daily driver.
Hardening2753
Ford Maverick Hybrid
How much did all the parts set you back?
GPSMan
Many
Ford Maverick Flat towing the Maverick? 24CBED5D-E9EB-4363-B117-E1CB5BB57B2B
Ford Maverick Flat towing the Maverick? 6BC23314-507D-4466-81AC-6E51C72F6A98
Ford Maverick Flat towing the Maverick? FB5A11FD-9615-44A9-80FF-545B3A0A75CE
Ford Maverick Flat towing the Maverick? 121E9D7A-B139-4585-8748-0C5B80D7DB9D
You tell ignition is "on" because fuel is reading "F" above.
Ford Maverick Flat towing the Maverick? 1468F2FD-CE61-4AF4-869F-ACC8F1050B6F
You can tell ignition is "0ff" because now there is no fuel (or temperature) sender data above
Next, I started to roll down a gentle slope in an empty parking lot since I did not have an RV to "tow" my Maverick. I started at a dead stop
Ford Maverick Flat towing the Maverick? FEC80AFC-A77E-4D15-B5C2-6B3DFF4965F5
At ~4 mph both generator and traction motor were being spun
Ford Maverick Flat towing the Maverick? 43B616CA-6B52-4E39-BD0C-9C42DAF686D7
Ford Maverick Flat towing the Maverick? 45479576-A7B7-4B53-AD4B-4794509E5BC7
At ~ 5.25 MPH
Ford Maverick Flat towing the Maverick? 4AA063C4-080F-4587-B38A-9F53F1EB4E41
Also you can tell the ignition key is to off by looking at the 12v system. At 12.1v you know the DC/DC converter is off. Normally it provides 14.5v to 15.0v.
The scary part is the truck is consuming 6 amps in TOAD mode.
(which is why you'd want power from the RV that I didn't have for this short roll downhill test).
