- First Name
- Steve
- Nov 9, 2023
- Elbridge New York
- 2023 Maverick XLT 4K, 2025 Ranger STX 7.5K
- Engine
- 2.0L EcoBoost
If it's the same switch ground is common. I attached mine to a bolt above the brake pedal. The switched leads go back to the module and the LED ring positive can go either to the always on 12 volts so it's always illuminated or to the switched positive wire so it's only on when you have the fogs on.I got this same switch to swap out the one from DD, but am confused on which leads it goes on - i assume the ground chassis goes to common, and then the others are NO and + ?
