FischAutoTechGarten
Peter
I have my materials now.... just need to do a bit of work with the harness to take advantage of the F150 headlight/foglight switch assembly and keep the backlight functionality (I dig it).
In-laws were here for 20 days... brought Covid from NY, so everyone has been quite ill (we are all vaccinated, but it was still nasty... but no hospitalizations)... Everybody is better and just took them up to Tucson on Monday to fly home on Tuesday.
Now I have to do my install!
Mervin the Maverick
Ken
Sierra Vista, AZ
2019 Kia Niro, 2019 Hyunda1 Kona, 2002 Chevy S10
Do
You cut out the fascia to install them and they cover the opening you make completely. They are made to fit into the grooved surface and you end uo with a factory looking installation. Fit is very professional and you really can't mess it up. Just take care and follow the instructions on you tube. I have the backlits on whenever my truck is running and the fogs on when I turn on my running lights. I used my own on-off button. They are impressive and light up the front and sides extremely well. I would not hesitate on buying them. I doubt you will find a better working or nicer looking set. They may look small but produce quit a bit of useable light at night....esp if you are watching out for deer on the sides.
Do you need to remove the facia, or just use a Dremel or other device of ultimate destruction to remove than panel?
Mervin the Maverick
Ken
Sierra Vista, AZ
I would like a switch inside the cab, but I’m not sure how to do that…. Yet…..
raymaines
Ray
Tacoma, Washington
Alto Blue Lariat Lux Hybrid
I've got no actual use for fog lights, but this kit looks extraordinarily attractive. If I find $300 under my pillow tomorrow morning this is how I'll spend it.
94tbird
94tbird
Ron
Treasure Island
2024 Ford Maverick Lariat
Do
I cut mine with a razor blade. went nice and slow so no deburring afterward like if i had used a dremel
94tbird
94tbird
Ron
Treasure Island
Do they turn off with the high beams?
Good question, i believe they do since they have an activation wire tied into the passenger headlight
94tbird
94tbird
Ron
Treasure Island
Mervin the Maverick
Ken
Sierra Vista, AZ
I honestly haven’t looked yet, but is the 12vdc being fed to high-beams and low-beams on the same circuit (or wire?).
OleFordGuy
Those are AWESOME!!!!!
Headbanger
Ron
Finleyville PA
2023 Maverick Hybrid Lariat
Wow! Looks fantastic! Gotta snag a set myself 🤘
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
Mine stay on with the high beams unless shut off. Mounted a switch to the right of the headlight selector. Don't want them on unless I need them. Having them on with the high beams in fog/snow/rain is counter productive as they ruin the distance sight anyway.
Your switch looks great.
Barracuda340
Abilene Tx
Agreed I plan on switch placement in the same spot. I ordered 12mm pushbutton on in amber but with the power on symbol. The yellow ring looks really good too.
gp1200x
Paul
NY
I used a dremel and then a microfiber cloth to debur...breaks off the remains easily. You have to remove the front fascia from the truck...if you already installed fender flares it will be somewhat of a hazzle. DD does include wires with their relay block...power with a fuse, ground, backlit amber wire, foglight activation wire and a deactivation wire - incase you really want them off with your highs.
https://www.mavericktruckclub.com/forum/threads/foglights-installed-diode-dynamics.42427/
This link provides more info and there is a video on their site that shows how to install. I wired my up differently but to each his own. I would have easily paid Ford $300 for these fogs.
My wiring...
Deweyordeweynot
Dewey
Macomb, MI
Glad to hear you're all on the mend. Good luck with the install and if you can, lots of photos of the process!
