That is correct, the F150 switch gets plugged in the same as the oem one. The wiring you'll need to do for the fog light harness will be off off the BCMIs the F150 headlight switch plug-and-play with the connector that comes on the Maverick headlight switch harness? No wires get terminated to the F150 switch, correct? The green wire that gets terminated to the BCM should have its other end terminated to the white wire of the fog light harness, correct?
