And yet again...another dead Hybrid
NJ Pinelands
New Jersey
Chevrolet
Dealer came and jumped it. They installed new battery and new software. Went dead again. Rep called me and to remove the truck from Ford Pass app on a Friday, they called me Monday and said it was fine all weekend and I could pick it up. Nota problem since. They said the app was actually draining the battery as it was over communicating with the truck. I also turned off the trucks Wi-Fi. I was told not to add the truck to the app until there is a fix.
I wasn’t planning on signing up for the Ford Pass app anyway so this is another reason not to. As long as I can drive it without the app, I don’t have any reason to use it.—By the way, I at least heard back from one of them.
Guardian
Northeast Ohio
Smartcar,Alfa Romeo Spyder,Pontiac GTO,Taurus SHO,Mav Lariat
You read my mind! This is my first hybrid and after seeing the battery/electrical problems I use my hybrid like it was my first new car('78 Mustang) radio only. I turn off the automatic lights,don't use the AC,no use of apps,no phone connection...etc. Following these blips carefully,no problems so far but watching.
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
No AC? Really? Honestly, I think your hybrid will be fine if you use the AC and automatic lights. As for the other stuff, I don't use them either because I have no use for them.
Guardian
Northeast Ohio
Agree. No problems so far...but when you live in Northeast Ohio AC use is (for me) not that big of a deal.
Gullzway
OK
1968 Ford Mustang Fastback
Just my opinion, but the Ford Pass app communicating with the truck should have zero to due with the 12V battery not being charged from the Hybrid battery. It's more likely the cable connection in question. I've had no Deep Sleep/Remote features disabled messages since putting a small clamp on the connection.
And I only got the one when I wiggled the connection to test it, which likely momentarily broke the connection.
Sliphorn
Missouri
Are you taking your MAV to the dealer to have that connection looked at? The Ford app has caused problems for some. It can cause a 12v battery drain. Chicago Mike seems to be experiencing the problem.
Gullzway
OK
Not until a recall is issued, or if I have another problem with it. When I called, they had heard nothing about the issue and wanted me to leave it there for at least a week to diagnose it.
I run the Torque Android app daily and check on battery voltage, consistent 14.5V when running.
D Janke
Phoenix AZ
2022 Ford Maverick Hybrid Lariat !
ok just as a precaution, I now too have removed my Lariat Hybrid from the Fordpass app.
I just don't need this kind of headache from a brand new truck!
huunvubu
coppell tx
2023 Ford Maverick Hybrid
Dealer is just making sh*t up. The FordPass App is NOT draining the battery because if that was the problem many tens of thousands Maverick Hybrid owners would be reporting the issue.
They actually are just wild-ass guessing as to what the problem is because they have no clue.
Expect the problem to reoccur.
Chicago Mike
Chicago Mike
Oklahoma
2022 Shadow Black Maverick Hybrid
Thanks for telling me to expect the truck to die again. I need that positive reinforcement.
Sliphorn
Missouri
There was a notice from Ford about disconnecting the FordPass App. I think it had to do with using aftermarket, not Ford approved stuff. I will try to find it.
93nighthawk
Eric
South Dakota
Chris_G
NOVA
C-6 Corvette
