BradMav
Brad
2024 Ford Maverick
FYI I think both of these options are in EASY mode now for IPC, I did it without as-built codes to change to square signs. What I don't have is the color inversion after some time. The signs stay for a while, then disappear, no inverted colors.
Note: Disabling TSR in IPC means a little bit more than square vs round signs I believe. You lose the recognition of signs other than speed signs with this change. The only other signs it recognized for me before making this change was passing zone signs, which for me wasn't so useful anyways and didn't seem reliable. I am not sure, if there are any other signs others have noticed it recognizes with TSR enabled?
@nickn066 - Do you mind sharing how you came up with these codes? I'm curious to learn how people are discovering these codes. What's interesting for me is when I used EASY mode to enable SLIF in the IPC module, it actually set 720-09-01 to xxxx xxxx 9x, 9 instead of 8. For those that understand binary, I think that's because each hexadecimal value actually represents up to 4 different settings (aka bits):
Hex value 8 represents 4 binary bits: 1-0-0-0.
Hex value 9 represents 4 binary bits: 1-0-0-1.
What this tells me, is it is probably only the first bit being turned on that actually enables SLIF. But... I guess this also means that if I would have entered "8" into as-built, I might've been unknowingly turning something else off (whatever that 4th bit set to 1 represents).
F150 settings, while using a different address for this, has the following configuration for value 8:
8 =TSR enabled • TS disabled • TBS disabled • TSP disabled
This seems to match what I mentioned previously, where 8 represents in binary 4 switches: (1000: On, Off, Off Off)
So, setting it to 9 (1001: On-Off-Off-On) I guess keeps TSP enabled. I had to Google what the heck is TSP, i guess it is the feature that lets you pause your trip meter by pressing the "OK" button. I guess most people didn't even know this feature existed (i didn't!), so probably not a big deal for most, but it's good to be aware if you are setting values in "As-Built" mode, be warned, you might be changing 3 settings that you didn't intend to change by setting 1 value!
TruckPrius
Home
'23 Maverick Lariat Lux CP360 Assist
Just did this myself via easy mode on my Lariat as well
IPMA settings:
  • Traffic Sign Recognition (TSR) - Speed Limit Information Function (SLIF)
  • Traffic Sign Recognition Mode - Camera data only
IPC settings:
  • Traffic Sign Recognition (TSR) - Disabled
  • Speed Limit Information Function (SLIF) - Enabled
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Got this working but don’t see all the other options others have, just these.
I don’t want anything beeping or going crazy if I happen to accidentally exceed the speed limit going down hill😉
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) IMG_3088
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) IMG_3089
Automan21
Mel
I don't have this one coming up. The activate TSR one.
Eventhough I got this to work at my first try at FORScan I hope I didn't mess anything up. I did use the easy mode to change things not the numbers way.
If you enable the TSR option in the IPC then the menu appears. You may not actually need to, though, as just enabling it in the IPMA will still allow the instrument cluster to start showing the sign indicator. Ironically that's actually one of the factors between getting the round signs and square signs in the Lariat cluster, it seems.
Automan21
Mel
Oh ok, I guess I did it right by accident since the signs show up as squares lol.
Thanks guys for the info and the confidence build up.
Toinky
Toyota Tacoma
I have a '23 EB Lariat Lux FX4 Tow. I successfully enabled TSR in easy mode, but initially had the round signs (European?). When I changed the IPC to enable SLIF, the square signs (US) appeared as they should. See post #452 for the simplest of instructions, although I enabled the TSR in the IPC. This gives you the I/O option on the cluster (for Lariat's, at least).
Raphaelfns
Raphael
Brazil
2023 Ford Maverick Lariat
Hello friend, Raphael from Brazil here.
Why on my TSR shows two speed signs, instead of one? Can you guys help me?
Thank you
Macomb, MI
Raphaelfns
Raphael
Brazil
Eldrick1
NW Suburbs Chicago
2024 Maverick
IPMA settings:
IPC settings:
Just want to say thanks. Tried this again this morning, after thinking it did not work to enable the US style speed limit signs on my 24 Lariat, and it worked perfectly. Very happy to have the square signs now, after trying before and thinking I was stuck with the Euro ones.
Thanks again to all who contribute!
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
I did it on mine I'm going to wait until I'm in the road to see if it works with the Ford Explorer IPC lol.
pantera156
Pantera
Porto Alegre
lariat 2.0
Working! But for some reason it doesn't show anything on the right side. :crying:
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) photo_2024-07-24_01-03-34
