Traffic sign recognition on an XLT FX4
generalmgr
generalmgr
Wes
Clarion, PA
2023 Maverick XLT EB
Here's the only thing I've ever seen in the right bubble on my Mav:
Does the circle on the right get that symbol after going by a no passing sign? I’ve only driven around town so far, haven’t been in any passing zones.
generalmgr
generalmgr
Wes
Clarion, PA
There might be a difference between the 4" and 6" cluster, though I'm not sure why. The only option I didn't enable was the Speed and Overhead signs. Those three settings worked for me. Unfortunately, I don't have any other suggestions. Good luck!
Appreciate the help. At least your method enables it, with the circles on each site. My ocd was at max level with both of them on the left and the thing looking off center. 😁
TheShark
When I enabled TSR using some of the as built suggestions found here, I too get both circles on the left. When I use jerrisn’s method, I get one in each side, but only after putting everything else back to stock.
It's amazing how we can all be doing pretty much the same thing and get different results. I too used the jerrisn method. Now HolyCarp and I are XLT FX4 so I would have expected the same results but obviously not. I wonder if he used the jerrisn method? You have a XL which has a different display so you might have expected different results and of course jerrisn is a XLT hybrid.
HolyCarp
DFW, TX
2023 Cactus Gray XLT Eco AWD FX4 4K
Yes. Only one street near me has the no passing sign. I didn't even notice the street sign when I first turned on the street. Drove down the street again just to confirm.
generalmgr
generalmgr
Wes
Clarion, PA
I actually have the same as you….xlt fx4. I also have cp360 and lux package, if that matters at all.
HolyCarp
DFW, TX
This is the thread that I followed to enable my TSR. I used Method 1 but didn't activate the speed warning and chime: https://www.mavericktruckclub.com/f...ition-tsr-forscan-mod-confirmed-working.9399/
BlackMav23
MI
2025 Lariat (Shadow Black, 4k Tow, Sunroof)
Only because I had such trouble getting this to work until others shared their methods...
If anyone stumbles upon this thread trying to get this to function with rectangular signs on the FX4, this is what has worked for me.
Performed on 2023 XLT FX4 w/Lux, 360, Tow Pkg:
  • IPC
    • Disable “Traffic Sign Recognition (TSR)”
    • Enable “Speed Limit Information Function (SLIF)”
  • IPMA
    • Set Traffic Sign Recognition (TSR) to “SLIF”
    • Set Traffic Sign Recognition Mode to “Camera Data Only”
  • After flashing you will have to enable it in the menus of the vehicle itself.
Whitty1
Dennis
Clover, SC
2024 Lariet
Hoping someone has a solution.
I’ve read every article I can find, watched every video available. Many were very helpful, thanks to all who take the time to help others learn the tricks.
I’ve had no issues programming all drive modes, eco coach, and turned off the a/s/s.
The one thing I can’t get the way I want it is the TSR. I can get it to display two circles , the speed limit shows up in the left circle. The circle on the right is blank. I have never been able to get the rectangle traffic sign to display.
I have tried every suggestion on this forum, to no avail. I have reset the modules back to stock, and started from scratch, at least twice, with every different suggestion.
I even tried messing with things a bit on my own. Still nothing.
Right now, I have it set so the circle speed limit shows on the left, and a blank circle is on the right. That’s better than nothing, I guess.
Has anyone with my configuration been able to get the rectangular speed limit signs to display?
Mine is a 2023 XLT FX4 Lux CP 360 4k tow with the bigger cluster screen.
Thanks
I have been having the same issue tryjng to set up TSR on my 24 Lariet.
Thanks
ive been having the same problem setting up TSR on my 24 Lariet
Whitty1
Dennis
Clover, SC
2024 Lariet
  • IPC
  • IPMA
when I tried those IPC settings, my speed limits changed to MPH to KPH
