Gullzway
OK
1968 Ford Mustang Fastback
Then use
706-01-01
xxxx-xxD2-xxxx
instead
706-01-01
xxxx-xxD3-xxxx
is not a valid code for Mavericks then
Hmm, not sure if that's the problem. More likely the weird speed limit of 17, never heard of that.
Maverick2022XL
name
hinterlands
The only surefire way to rule that out is to use a known good IPMA setting and see if it registers or not.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
hmm might have to get this mod working as I have a daughter that will be of driving age soon....
DanielHSmith
Daniel
Missouri
Got it all enabled. Not only after you do it in Forsan, you have to go into settings and enable it, then turn on the screen.
Did you get this all working in easy mode within both the modules? if show, can you show those?
DanielHSmith
Daniel
Missouri
Here is what I did in easy mode today to get TSR working (FX4):
IPC Module
Chimes - Traffic Sign Recognition Overspeed: Disabled -> Enabled
Menu - Traffic Sign Recognition Activation: Disabled -> Enabled
Traffic Sign Recognition (TSR): Disabled -> Enabled
IPMA Module
Traffic Sign Recognition Mode: Disabled -> Camera data only
Traffic Sign Recognition (TSR): Disabled -> SLOIF
I am thinking about changing the SLOIF to just SLIF as I dont think I want the extra circle for the "no passing" sign.
Does anyone just have the single circle for "speed limit" ?
mdl20813
Idaho
Cactus Gray Maverick XLT
IPC Module
IPMA Module
Are you on a beta version of ForScan? My 2.3.46 version didn’t have easy mode for IPMA and gave me service interrupt for the IPC changes. I’m not super familiar do not sure how to go about getting the beta versions that may have those updates.
Gullzway
OK
Check Post #102. Not sure if that's how to get easy mode though, as my Maverick isn't here yet.
mdl20813
Idaho
Yeah I found the link to the 2.3.47 download. I loaded it up and was able to enable TSR right away
DanielHSmith
Daniel
Missouri
So I messed with this again today trying to just get the speed limit (left) circle to only show. With either SLOIF or SLIF both circles are still showing. Has anyone been able to get only the one (left) circle to show and not have the translucent (right) circle showing?
SLOIF (Speed Limit Overpass Information Function) aka speed limit and no passing sign
SLIF (Speed Limit Information Function) aka speed limit only sign recognition
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) PXL_20220321_000116641
Cruzer01
Nighowl2000
Roy
Ottawa
Just enabled it. Need the latest version of 2.3.47 March build if you want the easy modes.
Edit: tested and working! Perfect mod if you have teenage kids!
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) IMG_20220321_162646542
Alejo90
Alex
St. Augustine
22 Maverick
Hey guys, i was having trouble writing this mod until i installed this test version sent from Forscan
https://forscan.org/download/FORScanSetup2.3.47.test20220310.exe
(not sure if the link will work) but its a Test dated march 10th. Anyways easy mode is available for both IPC and IPMA modules. I'm not sure what the right "ghost" circle is supposed to show.
Truck is a 2.0 AWD FX4 4K
Using Surface Pro
Forscan 2.3.47 test20220310
Vgate vLinker FS
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) Dash
DanielHSmith
Daniel
Missouri
Using Surface Pro
Vgate vLinker FS
The right circle is for "no passing" signs. I'm not sure that there is a way to get rid of it. I have not figured it out yet.
