Tailgate Assist Strut - Binding with the tailgate cable
FalconJim
Leavenworth, Kansas
2025 Lobo High
I installed a tailgate assist strut, following the instruction video - but the tailgate cable binds on opening and closing. Did I do something wrong? I considered just removing the cable, but wanted to see if there are others who've had and overcome this issue?
Johnkn
MD
Which way is the strut rod facing?
A pic might help...
Cancunbadlands
Cancun
Cancun
No issues at all
Ford Maverick Tailgate Assist Strut - Binding with the tailgate cable 20250830_152554
ShadowBlack XL440
Robert
Northern Ohio
I agree, a picture is needed. I have never had an issue with that.
Jim DO NOT REMOVE THE CABLE.
I haven't had any problems.
Pictures would sure be helpful.
I just took this 8 sec. video. Showing how mine works.
Jim, what appears to operate differently with yours?
Ford Maverick Tailgate Assist Strut - Binding with the tailgate cable IMG20260224170020
The cable hangs on the inside of the strut.
vandeda2024
US
2025 XL Hybrid, AWD, 4K
I had that problem. It was because the plate the strut attaches to rotates, moving the connecting point of the strut. The cable can then move behind the strut when the tailgate is closed.
Solution was loosen the bolt holding the plate, rotate the plate so it's vertical, and then you have to really crank down on the bolt so the plate doesn't rotate again.
FalconJim
FalconJim
Leavenworth, Kansas
2025 Lobo High
tom_tucker
mid atlantic (VA)
2023 Maverick XLT (FWD)
I would never install TA b/c of these many little issues. However, sounds like a bit of loc-tite on the bolt threads could tidy it up.
vandeda2024
US
I would never install TA b/c of these many little issues. However, sounds like a bit of loc-tite on bolt could tidy it up.
The problem isn't the bolt actually loosening. It's just how the plate mounts, if it's not tight enough, it can twist since only 1 bolt holds it on. It's been OK now for about a year now though.
tom_tucker
mid atlantic (VA)
🤷‍♂️ Never mind then, don't use loc-tite on the threads or interface.
I hear sound, see no video
I have the same problem when I try to review the video on my older Samsung.
Here are some pictures I just took.
Ford Maverick Tailgate Assist Strut - Binding with the tailgate cable IMG_20260224_100117
2 YEARS ON THIS STRUT & MOUNT WITHOUT A PROBLEM. $19.99
Ford Maverick Tailgate Assist Strut - Binding with the tailgate cable IMG20260224095411
Ford Maverick Tailgate Assist Strut - Binding with the tailgate cable IMG20260224094934
EVH5150
Southern Vermont
I never had a problem with mine, but there was an Etsy shop selling a 3D-printed device that guides the cable into the proper orientation every time. I bought one to prevent any future aggravation; works like a charm. Sorry, no link, I can't access Etsy on my work computer.
