Shuddering Hybrid
Dad
Yeah, the shoulder warning, here in texas it looks like the highway department drove a dozer down the shoulder. It will wake you up. Great analogy.
Didn't you once live in Cypress, moved to Irvine? Now you're in Texas?
Dad
Dad, glad to hear others know what we are discussing, mine didnt do it until lately, brand new it was perfect. Sorry to hear yours is doing it. I have 10000m.
How many miles you have on yours?
If my hunch is right, this could be serious, repair is engine removal?
Thx.
I have just over 4k
Mach 1
Mach 1
Randy
Spicewood
2022 Maverick Lariat Hybrid sold 2024 mav hybrid 2018 F150 Lariat 3.5 ECO
Dad, damn, thats about when i noticed on mine was exhibiting the symptoms. You couldnt get anything out of dealer? Skinny was saying something about a code, i need to check into that more. Its too far along to live with, does it about 50% of the time i regen, which is every time i slow down.
I have lived in central texas since 69. I have been to cypress, irving, no residence, went to Galveston 75-79, came back to austin, live in Spicewod now, but wife and i cruise everywhere, all the time, Marble Falls, Johnson City, Frederickburg, Llano, Burnet, Kingsland, Blanco, RR, Georgetown, Buda.
I had my own diesel repair/modification business.
Do i know you? Or you know of me?
I live near Burnet. I have 5800 miles on my lariat FE and have not noticed those symptoms that I recall. I did notice some Regen improvements when I started to use econ mode at about 2500 miles and even more after 4500 miles when I started using the Low button which according to manual can be pressed at any speed so it apparently just uses different settings in the program. It vastly improves Regen braking. Maybe your symptoms are related to the Regen braking. If you have not used econ mode and low mode enter it when in standard or econ maybe the computer needs some input from those to improve it's Regen. Do not know but why not try. I would doubt it's the damper but would suspect something in the planetary gear selection if the ice is started at the time you are experiencing the symptoms. There were reports posted of several having to have some updates to their program if theirs was made before March if I remember right. I don't remember enough to search for it. Good luck, maybe see you around.
Mach 1
Mach 1
Randy
Spicewood
Makin, I am in Burnet at least weekly. Nice place, eat at Mamas.
I could be wrong however, i believe its going to be fairly wide spread problem. Talked to several people now and more are noticing it, even had dealer look into it on some of them.
Mine did not have it till about 3-4000m, it was just noticed, then about 8000m its happening pretty regularly, now at 10000m its enough to get my attention, its happens 50% time on slowing down. Its getting more violent.
Have you seen any improvement in FE with ECO? I am getting pretty good driving on 281/71 as i can get 60-70mpg with 20m trip and about 8m electric. Still pulling down 700mpt using highway more.
If you want to meet up and talk/compare Mav and you can drive mine and see what i am talking bout. Skinny suggested loading it down and see if it slips and throw a code. I have only seen it while deacceleration but havent jumped on it hard enough to see if its slipping in forward.
clavicus
Do you notice it more on uphill vs downhill?
Mach 1
Mach 1
Randy
Spicewood
Hey Makin, good advice, i have been running ECO mostly since I bought the Mav, trying to determine if i can pull down 700mpt without using ECO.
My shuddering comes in when deacceleration, after a second of regen, like its going to change mode/gear ratio.
Heres the kicker, does it without ICE running. I will recheck to make sure, yes i need to take notice which mode, when its shuddering, etc.
It did not do this when new out to about 4000m. Since then its getting worse.
Mach 1
Mach 1
Randy
Spicewood
Clav, i havent noticied either way, i am going for a cruise and will take notice of uphill/downhill, ICE, Emode, operational mode, etc.
I usually feel it deacceleration, i drive mostly in ECO, so i tried norm, same. About 50% of time i feel it. I guess another would be how fast mph, it occurs and then maybe vehicle load, like downhill. There has to be a good road surface, cause any vibration interferes with testing. Seems like it does it at highway speeds, but it tough to seperate, is it the road surface or vehicle.
Thx for input everyone, now just need to drive it and make observations, will keep in touch.
skinnyboy
Andy
Ontario, Canada
Hopefully it's something easy like a bad CV joint, but that would likely be noticeable under acceleration as well.
Cheers.
Mach 1
Mach 1
Randy
Spicewood
Ok, just got back, slight uphill, norm mode operation, hybrid mode, 35mph, release accelerator, regen starts, 1-2secs on regen(another mode or gear ratio change is about to happen), then drivetrain shudder, felt in steering wheel, audible, minor vehicle shudder.
If you are keeping up with location, Marble Falls, 281S, right before post office, up hill.
I dont think alot of people are noticing it because it starts out minor and gets more aggressive, you have to be on a fresh paved road, turn radio down, and feel for it.
Mine is getting worse and now i can feel it pretty regularly. I tried to get it to do it and on the highway, couldnt, tried different modes and up/dn hill. Does it in city 35-40mph right now.
Mikknj
Mikk
New Jersey
Maverick XLT Luxury CO360
I just took a long road trip. The shudder was happening as others say when I lift my foot off the gas and regen starts. I tried all different modes. No different. I did not have this problem till 4000 Miles. Now it's fairly often 50% of the time. And getting worse. Also I noticed the problem goes away when I turn the air conditioner off. So I think the load on the system is affecting this shudder in some way. ( but it's 90 degrees so I can't drive it around like that) I suspect the regen system has a programming issue. It might be weather related since I never noticed when the truck was cold in the Spring. I don't think this is a clutch or mechanical issue. To me this is a sensor issue with feedback to the computer causing some fight in the transmission/ trying to change gear ratios.. It's like a harmonic because it's always the same low frequency vibration.
Mach 1
Mach 1
Randy
Spicewood
Mik, good observations i will try the AC deal, good thoughts, i think the clutch damper as that is what i relate it to, plus its getting worse, more often, more severe. Its almost to the poont of not driving it, it sends prety good vibration through thewhole driveline/vehicle.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hello, Mikk! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this shudder concern. Thanks!
Bamabrowns
Loxley, AL
Maverick Truck
Just wanted to add my 2 cents. My Maverick XL Hybrid went down 10 days ago. They narrowed it down to the Flywheel and Dampener. Doing 80 mph passing a truck and there was a loud metal clank. The gasoline engine shut down immediately.
JAC
Full time RVer
Chevy G30 Roadtrek Van, waiting for Hybrid XL Mave
Wow!!! How difficult was it to pull over ? Have they given you any estimates as to how long the repair will take?
