Issue: Automatic Dome Lights Not Functioning
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
I put a solar charger that seems to help with the battery drain.
Ford Maverick Issue: Automatic Dome Lights Not Functioning IMG_20230122_103508
Krrr
SW PA
2022 Maverick Hybrid
I like the Solar Charge idea. If I have it putting the charge back thru the cigarette lighter, will the current flow stop, to the battery, if the car is turn off and the cigarette lighter auto disengages? Does this mean you have to wire to battery?
RJC
RUSS
NL CANADA
2022 FORD MAVERICK CARBO GREY AWD XLT
My ecoboost gets the deep sleep message sometimes , use a trickle charger to top up the battery. No more messages.
Krrr
SW PA
My Hybrid is 5/10/22
Whats your EB?
Scupking
2025 Ford Maverick XLT Hybrid
Mine is in deep sleep every day.... Thought I solved it after turning wifi and all the connectivity features off after doing the radio software update. It took about an hour. What must have happened is it charged the 12v during that time as my Mav was good for a week after that and then deep sleep started again... Today I drove 20 miles and as soon as I got home it went back into deep sleep (dash and interior lights don't come on when opening the door)... When are we going to see a fix for this issue?
  • Sad
Reactions: Aza
Krrr
SW PA
"Deep Sleep"
Is build date critical with this problem?
Could this be related to the Battery Harness Issue?
That date was around 3/10/22.
My Hybrid was 3/10/22.
This Truck is still a keeper.
roc129
Woodstock, GA
97 Mazada B2300
This will not get fixed until Ford recognizes it as a problem and assigns the proper resources. I have the same problem with my Lariat Hybrid built 3/8/22. I have had it looked at by two Ford dealers and have an open case with Ford Customer Care case. I now have to charge the battery using a trickle charger then reset the BCM. It doesn't fix the problem, just prolongs the deep sleep.
Dad
Same here. I asked my local dealer service rep about it and got a bunch of Fordspeak about how the Maverick uses sophisticated electronics that require power, yada, yada, do. No kidding. They want us to believe the Maverick is the first? They're not addressing the problem. More of us need to complain either to dealers or directly to Ford.
jmrlab
Southern Tier, NY
2016 Colorado, 2025 Maverick XLT (came from a 23 XLT)
Deep sleep on an EB? This is the first post I've seen with this issue on an Ecoboost. Temperature related?
Scupking
I'm at 1k miles on mine. When I bring it in for the airbag recall I will tell them about the deep sleep issue...
  • Like
Reactions: Dad
Krrr
SW PA
Warm weather
Michaelkov
Michael
Atlanta, GA
2021 BMW X1, 2018 Toyota Rav4, 2022 Ford Maverick
Interior dome lights no longer automatically turn on when opening door.
Either exiting or entering the Maverick - automatic dome lights no longer functioning
Any advice is appreciated. Thank You
Probably not a loose nut behind the settings controller...
Ford Maverick Issue: Automatic Dome Lights Not Functioning 1678017513722
Krrr
SW PA
Oh, You got "Deep Sleep". But in it's early stages the truck still starts. This is the stage my truck is in for about 5 months. Trying to guess what the next step is:
Transmission
Battery
Battery Cable
Problems.
But I do love my Truck. It's perfect, except.
Gullzway
OK
1968 Ford Mustang Fastback
Still no fix for deep sleep issue and dome light yet huh?
Charging the battery overnight then resetting the BCM fixed mine for 1.5 months. I just got a deep sleep message last night but I think it's due to adding a enclosed powered subwoofer which has been turning on randomly as I wired it into the speaker line input. Even opening and closing the doors causes it to trigger. I'm changing that to a remote wire from the ACC today.
Ford Maverick Issue: Automatic Dome Lights Not Functioning Screenshot_20230131-185458
