- First Name
- Mike
- May 3, 2024
- KC Metro area
- 2005 Toyota RAV4, 2024 XLT Hybrid
- Engine
- 2.5L Hybrid
Ken - since you have 25 - I'd be curious if you see a difference.Double lock notifies computer you are through with truck for awhile and to advance shutdown of possible delay items. If you are in neutral tow and put in park then do not do anything else for 15 minutes. Double lock may or may not be ok during that time depending on how good the program was written. Be safe do not due anything for 15 minutes while computer restores non neutral tow status of all modules.
It appears 24MY already changed and does the above with the single lock - as nothing changes between single or double lock - except the horn sounding if you have that option set.
Interior/exterior lights off at same time, screen & power points off at same time, ect.
I don't have 120V outlet to notice though.
Of course - I can only test this when the battery is NOT in max power saver mode - nothing like all lights off pretty much immediately on door opening! Not totally true, but close enough.
