Maverick2022XL
name
hinterlands
Applies to all trims w/AWD with or without an FX4 package.
This so far has been tested on an XL trim with a 2.0L gas engine, AWD w/o the FX4 package and has since been confirmed to work with the FX4 package option.
It has also been confirmed that it can be used on FWD vehicles. Performance testing still to be determined for FWD.
This assumes you know how to use Forscan. Also make sure you back up your ABS settings before doing this. If you screw it up badly a simple restore of your back up settings may not be enough. You might also have to do an ABS module reset afterwards.
There are 2 ways to go about this.
Method 1 - enable either the FX4 package or non FX4 package.
To switch between both
ABS
760-02-01
xxxx-xxxx-x*xx
For non FX4 package and eco / sport drive modes enabled change to xxxx-xxxx-x1xx
For FX4 package and mud / snow drive modes change to xxxx-xxxx-x8xx
Next you need to enable the selectable drive modes for the package you want active. See SDM section for drive mode selection.
Method 2 - This allows for all 4 modes to be usable at the same time
First you need to disable ABS as a selectable drive mode. This will bypass register 760-02-01. You can leave that setting to your vehicle's default setting.
ABS
760-04-01
xxxx-xxxx-x*xx
change * to 0 to disable the ABS drive mode selector
This now allows you to use all 4 modes.
Next you need to enable the drive modes. See SDM section.
SDM (selectable drives modes)
This is required regardless of what method you use.
shortcut code - recommended for method 2.
760-04-03
0000 0001 EB5A
This enables all 4 modes - eco, sport, mud and snow
To enable FX4 modes
FX4 package - recommended code for method 1
760-04-03
xxxx-xxx1-E1xx
This enables both mud and snow modes
xxxx-xxx1-x1xx
xxx1 = snow
x1xx = eco and sport not present
xxxx-xxxx-E1xx
Exxx = mud / ruts
To enable non FX4 modes
non FX4 package - recommended code for method 1
760-04-03
xxxx-xxxx-6Bxx
6 = eco and sport present / no mud mode
B = eco and sport
xxxx-xxxx-63xx
3 = eco w/o sport
xxxx-xxxx-69xx
9 = sport w/o eco
Decayed
yes
a car
So this disables the antilock brake system but enables all drive modes regardless of model?
And are you testing on a FWD or AWD vehicle?
Maverick2022XL
name
hinterlands
No it doesn't disable the antilock brake system. It is a special drive mode that locks those 4 modes into an either 1 or the other configuration aka FX4. Tested on an AWD vehicle. If you have drive modes on the FWD it should work. If not then it is not applicable. I'll make note of the AWD in the main post.
Maverick2022XL
name
hinterlands
I didn't get a chance to drive it in snow, sand, mud or deep ruts to test but I did do it the following way.
I set the screen to display the intelligent AWD and checked to see how each wheel was powered when I put it into the different drive modes going down the road. Every setting engaged the wheels differently from normal mode and from each other.
Ralli
Winnipeg, MB Canada
XLT Maverick
Cant wait to hear back from someone with FX4 that tries this
Decayed
yes
a car
This is something I've been waiting for, when I got fx4 I thought it added modes instead of replacing them. I wanted eco and sport mode and thought the mud/ruts and snow mode could come in handy in addition to the stock modes.
Maverick2022XL
name
hinterlands
If you do this mod let us know if it works on your FX4 package.
BlackXL
Cliff
Black Hills, South Dakota
2 F-350, 2 F-250, 4 escape, mustang, bronco
This so far has been tested on an XL trim with a 2.0L gas engine, AWD w/o the FX4 package.
This mod should work on all trims with a 2.0L ecoboost engine and AWD w/o FX4. It should also work with FX4 packages to enable sport and eco mode. Confirmation needed for these parameters still.
If you have a FWD this is probably not applicable unless FWD has selectable drive modes.
Method 1 - enable either FX4 drive modes or non FX4 drive modes.
ABS
760-02-01
xxxx-xxxx-x*xx
For eco / sport change to xxxx-xxxx-x1xx
For mud / snow change to xxxx-xxxx-x8xx
You just need to enable the selectable drive modes you want afterwards. See SDM section for codes.
ABS
760-04-01
xxxx-xxxx-x*xx
Shortcut code - recommended for method 2.
760-04-03
0000 0001 EB5A
To enable FX4 modes
760-04-03
xxxx-xxx1-E1xx
xxxx-xxx1-x1xx
xxx1 = snow
xxxx-xxxx-E1xx
Exxx = mud / ruts
760-04-03
xxxx-xxxx-6Bxx
B = eco and sport
xxxx-xxxx-63xx
3 = eco w/o sport
xxxx-xxxx-69xx
9 = sport w/o eco
Works on hybrid fwd xl too!
Ford Maverick ForScan mod - enable all drive modes: eco, sport, mud and snow (confirmed working) E273E8B2-6A64-48C0-858A-4001F987FF1B
Ford Maverick ForScan mod - enable all drive modes: eco, sport, mud and snow (confirmed working) DE0C3AB5-8419-4CCB-8AA5-2490624B285D
Maverick2022XL
name
hinterlands
When you get a chance to drive with the modes on let us know if they actually work and it is not just on in the ABS and cluster.
Mkuket
Massachusetts
Fun!! I used "easy mode" and enabled mud/snow and deep sand drive mode options but after selecting those modes it says drive mode not available. This post should resolve this for me. I was waiting for someone to figure it our!
Bushpilot
Greg
Spokane, WA
Chevy Volt
Wow, just wow. Unfortunately I am going on a trip, and will not be able to play with this for about 10 days.
I expect you hybrid owners to figure out the implications for us in my absence!
