Did your Maverick catch on fire or Suffer Engine Failure?
Mikknj
Mikk
New Jersey
Maverick XLT Luxury CO360
Let's call out some of the speculation around the Maverick Fire Risk recall and the Engine Failure question
Please let us know:
Has your Maverick caught fire?
Has your Maverick suffered a catastrophic engine failure - like a crank failure puncturing your engine.
Please show pictures if you have any.
I have personally not suffered any of this on my Maverick XLT Hybrid. And I bet it's practically not heard of except for the few already documented around the web - one looked on fire, the other that looked like a broken crank? Are there any more?
Catmandu
Ontario Canada
2022 Ford Maverick XL
No, is fine.
WesM
Wes
Maryland USA
Nothing of that nature for sure. only issue I have had with my Maverick (hybrid) is the low speed brake issue, where it locks up at 3-5 MPH when making a gentle stop/slowing down.
93nighthawk
Eric
South Dakota
Mine is hot enough to catch on fire! :cool:
FE Hyb. 710
Pennsylvania
Focus
Please let us know:
Zero problems after 2,300 miles on my hybrid.
Clarkdonbran
Ford Maverick Did your Maverick catch on fire or Suffer Engine Failure? A2FB9F36-96D1-44E1-815D-2CE69DBD5B91
MLA62563
Charlotte, NC
Honda Accord, Ford Maverick
Nope. Mine only looks like it’s on fire. 🔥😉
Six months, and three thousand miles of sweet satisfaction. 👍
RussellP IL
Russ
illinois
22 Mav hybrid. 20 escape hybrid
i had an external temp sensor go bad...without ac for a week, i was on fire. but the xlt eb was a cool area 51 blue
22XLThybrid
Paul
York, Pa.
2022 Maverick XLT hybrid (order July 21)
I was looking up an earlier recall on the crankshaft issue. (i'm not sure if it's this one or that is similar for 2021 Hybrid for the Escape, Corsair "Part 573 Safety Recall Report" but in that one 23 crankshafts missed a polishing process, which wound up in a possible 200 engines. Seems like a preemptive recall that addresses the build up of fluids in the event there is a failure, which could result in a fire.
So I'm thinking just because you have a recall to allow these fluids to escape and alter the cooling of the engine compartment doesn't necessarily mean you have a crankshaft that wasn't properly polished. So I'm thinking the failure rate is probably pretty small? I would like to see more pinpointing of actual failures and get an idea of how many miles one that isn't polished right goes before failing and what happens if it gets out of warranty. I am guessing there will be more details as time goes on.
tonyinsd
Tony
San Diego
Ford Mustang GT, Ford Maverick XL
How many of you are familiar with the accident chain? It's a term used in aviation where a bunch of things have to all combine to end up with an accident. Remove one of those things and the accident doesn't happen.
From reading this thread, we need to have the following things:
  • Engine failure
  • Metal fragments from the engine failure puncturing protective material
  • Oil and gas leaking through that puncture
  • Hot exhaust system igniting the fluids
Essentially, someone would have to have extremely bad luck for all of those things to happen. It's like worrying about a metal beam falling and hitting your head as you walk by a construction site. Could it happen? Yes. Is it likely to? No.
Just get the repair done by the dealership when your recall letter arrives and stop stressing about it in the meantime.
mcgarveyjb
Wisconsin
2022 Maverick Hybrid XLT W/Lux and spray in
You dont have to wait for the recall letter that is going out 8-8, you can schedule repair now.
Red Ryder
United States (TN)
22 Maverick XLT Iconic Silver
Uncontained engine failure plus flammable/explosive environment?
I was hoping for a bilge blower and fire-suppression system, but I'll probably just get a holesaw through the underbody aero-shield that will whistle in the slipstream and some grill-shutter vanes removed.
Seriously, I have over 8000 miles on mine now, I changed the oil last week. Mine was dry, the shield had no stains or drips whatsoever.
Not worried at the moment, truck is doing great!
It will be inconvenient if the 12V cable issue bites me, but hopefully not.
