So you got all this done and it's hook up to the stock Ford battery? No sleepy-poo issues? Man, all I know is if I did this when I had my stock battery, I'd be stranded somewhere in the desert.........in the dark...........hearing Coyotes calling my name...................A thanks to @TimeOutside for posting their 2000 Watt Removable Inverter Installation. This is basically their design with some more pictures. I plan to use this as an emergency generator if/when we lose power for a while.
The parts I used are: Inverted, Fuse Holder, Wire, 5/16 Lugs, Disconnect, Kydex sheet and a Crimper.
The threads on the battery terminals, inverter, and fuse holder are all M8-1.25. Needed one metric nut for the battery terminal with a 5/16 lock washer and washers.
All you folks who work with 2/0, respect man. My usual is 12 gauge and I wasn't ready for the ... challenge ... of working with 2/0. Every part of the job was a learning experience and, surprisingly, took longer than expected. The disconnect and fuse holders were both significantly larger than I had envisioned when shopping online.
