Generator Function / Large Inverter
Install an aftermarket 7 pin brake controller using the remote battery charging pins to charge your remote battery which is used to run your ac inverter.
I believe there is a fuze labeled "aftermarket brake controller"
If wiring into a hybrid Maverick you might want to read this first.
Interesting. Although it glosses over providing any specific number in relation to the current output capacity of the DC-DC converter.
Maverick2022XL
name
hinterlands
You'd have to get an actual Ford service or Haynes manual for that.
thevol
GA
Iconic Silver Mav 2.0 AWD 4k
If they had 3-4kw inverter on the hybrid similar to the powerboost I would be so tempted to get a hybrid, even without awd. I think they will add this and awd soon... hopefully.
Johnkn
MD
Honda 2k generator......
TimeOutside
Andrew
Hollister, MO
Maverick Lariat
Suggestion: Install an aftermarket 7 pin brake controller using the remote battery charging pins to charge your remote battery which is used to run your ac inverter.
Thanks. I'll check into this. Great idea.
FrankMG
Frank
Bend
Lariat
I'm not sure that it would be enough. Are there any decent alternatives? First of all I'm thinking about Honda(this), but who knows...
