How-to remove factory steering wheel switches (for installing other switches such as cruise control) - DIY
vezpa
XL
EMG
IL/IN border
Too many to list.
Trim
XL
Throwing a quick set of pictures up on my phone for removing the factory steering wheel switches, all you need is a flathead screwdriver and a t8 torx, use the random holes in the steering wheel from behind to pry and push the little tabs with the flathead and it'll pop right off, then use the torx for the screws holding the switches on.
Where are you located in Illinois? I may need to go for a drive.
Advertisement
Aufgeblassen
XL
Ric
Ft. Pierce, FL and Lake Placid, FL
VW Touareg TDI, Harley Street 500, Tao Motor TBR7
Trim
XL
Yes they require programming, this is a prerequisite to my programming thread.
So were actually successful getting it programed and it works? If so where/how did you get it done? Thanks!
I don't want to switch from an XLT to an XL, and find out it actually cannot be done.
lafire4you
XL
frank
california
maverick
Trim
XL
so I assume you have to take the steering wheel off to change the switch
bpcooper14
XL
'08 Nissan Frontier
Trim
XL
I believe that someone asked this earlier and the answer was yes.
Headdead
XL
Birmingham, Michigan
Boxster S
Trim
XL
Tyvemattis, It is not obvious to me how the switches are wired to the wire harness. Can you enlighten me please?
Tyvemattis
Tyvemattis
XL
Tyve
2022 Ford maverick
Trim
XL
There is a plug on each switch
[email protected] But
XL
Londonderry, NH
Maverick Hybrid x 1.5, Ford Ranger x1
Trim
XL
Years ago, there was a spring loaded sterring wheel and needed a tool to remove. Is this simply undo the bolt and pull the wheel off?
Thanks, can't wait to get this done.
Tyvemattis
Tyvemattis
XL
Tyve
2022 Ford maverick
Trim
XL
Is there a thread with pictures showing how to remove the air bag and steering wheel?
Turn the wheel 90 degrees each way, and use a pick or small flat head screw driver and you'll want to put it in the slot and push down
Snowbird
XL
Honda CRV 2018
Trim
XL
Thank's for the reply. I have been reading everything I can find about getting basic CC on a Hybrid XL with CoPilot 360. It seems like changing the switches is the way to go.
I get the basic jist of it but am still not sure of some things.
Do you access the slot from the back side of the wheel? Any other steps prior to this?
Other questions I have:
1-Has a part number been verified for the switches? You need to change both right?
2-Once you have it put back together and have Forscan plugged into the truck what do you do?
Advertisement
Advertisement
