I saw this on Amazon and wanted to make it easier to change my oil (on 2022 Hybrid) so I thought I would give it a try, Frencstr Engine Shield
I installed it today and the oil drain and filter line up great with the access panels, no more removing the entire shield!
This is NOT metal - it is a very thick piece of plastic, approx 1/4".
This is the material description from Amazon;
The instructions that were included was not correct for the Maverick, so there is a couple of "bolts" that I need to relocate for the front mounting points (see last pic with the correct bolt replacement from Amazon.)
https://www.amazon.com/Frencstr-Maverick-2022-2024-Suitable-Directly/dp/B0GS24J1RH
- Premium Material: Plastic steel is a kind of PVC profiles, due to its physical properties such as rigidity, flexibility, corrosion resistance, anti-aging performance, is usually used as copper, zinc, aluminum the best substitution.And is especially suitable for automobile chassis protect.Greatly extended the service time of the product.
