Wont drive stright
BK007
BK007
OH
Hi All Ive got a 2026 lariat Hibrid 3k miles when I took possession the truck would not trac stright no center either pulls right or left when lane centering engauged goes over lane markers and wips back like ping pong .Took it to Ford they were sciptical took a Tech on a test drive and it did what I said they have aligned truck and had to move the sub frame to do it ,They have replaced both frt axles still doing same thing does any one have experience with similar problem and what cured it ?
🚨 This doesn't make any sense here—there is no adjustment in a subframe. The engine cradle, struts, drive train etc. bolt in .... But nothing in the subframe is adjustable for a alignment...... 🚨
automator
Phil
Amarillo
'25 Maverick Hybrid;'09 BMW 335d;'91.5 Dodge W250;'89 E30;'86 Jetta (TDI swapped
The lane correction is shi* on these vehicles and will definitely overshoot at times. It's a torque-vectoring type of correction, not super smooth steering-wheel motor type found in other cars (VW/Tesla/etc).
It's not called CoPilot360 1.0 for nothing.
Turn it off and enjoy a happy life.
Gray Goose
RG
Wissota
Like the truck would hate to give up Thanks for the responce
Lemon status is a distinct possibility. Order a 2027 just in case. Saw a post that order banks open Monday.
pigsareus
Farmington Hills, Michigan
Maverick XL Hybrid
see if one of the brakes are dragging - if one caliper didn't fully release it's going to wander 'that way'
pigsareus
Maverick XL Hybrid
eventually if they can't fix it and you've had enough...just disable the ACC and move on - it's not worth the hassle, and you don't NEED it anyways. Yeah you'll miss cruise control .....
James K
NY
2022 Maverick,1960 Bugeye, 1973 GT6, 2016 R1200GS, 2024 KLX300
I had the problem but it went away when I stopped putting Tequila in the radiator. (sorry for lame joke, couldn't help myself)
scharris99
Daytona Beach
2025 Maverick XLT
I bought my truck new last year and it would wander, not tracking straight as if it was toed out. I checked the air pressure and found all 4 tires at 44psi. I dropped it to 35 all around and it not only started driving straight, but it rode much better. This has been a somewhat common occurrence with dealers leaving the air pressure at the transport setting. I would hope they checked that, but I would ask and then wait for them to have suddenly cured the issue.
Can you take a picture of the work order and post it.
If you really heard the service guy say sub-frame - I'm guessing he used the wrong term since there isn't one. Maybe he translated and used what he thought you'd understand, or he doesn't understand.
But the tech likely would have gotten correct words on the work order, besides what they noticed.
You should also ask for the before/after sheet from the alignment.
It exists. Nice to be included automatically, but should still be available.
And to replace both front axles under warranty for alignment issue!
Rather gutsy since they may have to send those in to Ford to justify a warranty on such a low mileage truck.
Unless they really talked to Ford advanced support and were told to do that.
The work order would spell out that communication too.
Gary, @Gman510
How many miles did it take, from when you 'took possession' and drove it off of the dealership lot, before you realize there was a problem?
Did you test drive it first?
AVC
North Texas
'23 Maverick Hybrid XLT, '02 Ranger, '20 Pilot
I've experienced more half-wits and loafers, than geniuses behind alignment machines over the years. Many tech's don't check for bent parts like control arms, struts..., defective parts like mounts and bushings, brake drag (anti-drag clips, defective caliper...), left or right favoring cross-camber, tire issues, steering rack binding.... I agree there is likely no intentional adjustment in lower strut bolts, upper strut mounts or the subframe, but tolerances in manufacturing and bolt holes provide for some adjustment, and the occasional conspiracy for all the fastener holes to be to one side of their tolerances and cause issues..
I'll venture Ford knows there can be tolerance stacking, and calls for an alignment check whenever control arms, struts or subframes are loosened/removed/replaced.
Gman510
GARY
Wrench$$2460
2026 Maverick Lariat
Good news 2 new Axles and Calibration has fixed the Truck Drives stright
