Weight Reduction
X4T8ee$
John Doe
Did a search for those terms and didn't find what I was looking for. Curious about how to drop the weight of a '24 Maverick Hybrid below 3,500 lbs. Tailgate and ¼ tank of gas being obvious....
Background is Ford Transit 350 HD AWD can tow 3,500 and I'd like to be able to do so. Thank you for any insight.
ThisWas
NH
2022 Maverick Hybrid, 2021 RAV4 Hybrid
Put the Maverick's spare tire in the Transit?
Dmat
Baton Rouge
MAVERICK
You're 1000# off. In order to stay within the Hybrids 6045# GCWR, you'd have to get the truck under 2500#.
HRG
He's saying his transit can tow 3500 lbs. He's trying to get the maverick to a low enough weight to tow it.
Dmat
Baton Rouge
MAVERICK
there isnt very much removeable on cars nowadays. beyond the basics like less in the fuel tank, remove the spare, there is very little left that doesnt require modification. Could probably go see what people in the fast maverick's facebook group have also removed to help them lose weight. I know its not discussed much but if you can switch out to much lighter rims, the rolling friction and the force to stop it should become easier to manage.
Ray-n-AVL
Ray
Asheville, NC
2024 XL Hybrid (Black), 2009 Yamaha V-Star Tourer
Does it have a hitch that you are not using and if so OEM or aftermarket? If aftermarket you could also remove the rear bumper bar if weight is more important than what would happen if you get hit from the back. The OEM hitch replaces the bumper bar.
Gray Goose
RG
Wissota
How much weight exactly does it have to lose to get to 3,500? Might need to scale it to determine exact weight. Various options add weight which results in a general range of 3,550 to 3,750. If you're at the low end, should be fairly easy to remove 50lbs with the tailgate, spare, jack etc. At the high end of the range, may not be possible.
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
Passenger and rear seats.
Waterick
Laurens county SC
The hybrids max suggested towing capacity is 2,000lbs. I'd advise sticking to that limit for safety's and warranty sake. Even IF it could pull that much you could experience handling issues not to mention stressing the drive train as the hybrid doesn't have the beefed up rad cooling etc.
If I understand correctly, the intent is to tow the Maverick with the Transit....
CurtisB
2023 Maverick XLT Hybrid
If the truck is too light, wouldn't that impede it's ability to tow?
I think this is a secret honeytrap to test reading comprehension.
