Unhood Insulation
asylus
George
TEXAS
'24 Ford Maverick Lariat Tremor
There are at least a few paths for the noise to reach you. Noise that is heard outside of the cab can obviously be transmitted back into the cab, just like any noise outside.
iThe pad will insulate noise from leaving the engine compartment. But It's also likely that the Hood could vibrate at times such that it will create some level of noise due to that vibration resonance of the sheet metal. The mass of the pad will change that vibration frequency to reduce that noise source, like any mass damper.
Ford may have met the noise target for the vehicle during development, just like any attribute target, and may decide it isn't worth more cost to further reduce noise, based on competition, etc. But the owner can always elect to add more cost if desired.
If my hood were to vibrate enough to cause a noise that I could hear within my cab I would not be worried about reducing the noise with an add on. I would have more worries. I have not at this point read any complaints about this being an issue but the earliest trucks are getting older.
Silver23
2023 Ford Maverick Lariat
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
CSP Racing best deal for me.... Under hood insulation made a real difference in the sound of the truck..... definitely , one of the best bangs for my buck
Can you post a picture? I currently have the Maxzina mat installed. It is modified to use plastic fasteners.
Ford Maverick Unhood Insulation IMG_4654
fderry
Frank
Colorado
2025 Lobo
Just curious - does a hood mat add enough weight to negate the use of aftermarket hydralic hood lifts?
Meeka
Jay
Castlegar B.C. Canada
2024 XLT 2.0 turbo
Good morning jay
I did not buy one.
I have no idea you have to ask the OP.
The op could not provide a link so, I would definitely steer clear of CSP racing.
Sorry Glen, I thought the OP would see and respond. Wasn’t questioning you!
El Kabong
Carnation, WA
tiktokbrainrot
around
91 F250, 20 GLI, 25 Mav XLT
I gave up the website..... it makes a difference..... gotta put it in your own work sometime..... Ebone84
If you have the website open....just copy and paste the link. It takes less time then writing comments. Dont be a boomer with the "well you gotta work" BS.
Also why are you taking pictures of a screen? Every ipad ever made can take screenshots, again it is not only quicker then what you are doing but it provides far superior image quality.
CarbonGrayFX4
Luke
Virginia
Looks to be the same as the Maxzina offering.
It is. I added dynamat just like you suggested. It works well. I wish it were flat, without the molded “y” portion. It would look more OEM that way. There is no OEM option unfortunately.
MaverickDragon
Grand Canyon, AZ
On the WallyWorld site:
Installation:
It is easy and fast. Align with existing holes, secure with screws and snaps. You will get 7 screws with threaded washers (including 1 set spare) , which will provide a sturdy hold and make it less likely to fall off ...
Good to know it's less likely to fall off...
Also would be interesting to see what "threaded washers" are..
Maybe they are like bolts and nuts...
MaverickDragon
Grand Canyon, AZ
Would this cause your motor to run hotter?
Considering that the engine is liquid cooled and the mat doesn't seal in the compartment, it's doubtful it makes any engine temperature difference.
The biggest temperature difference would be in the hood.
