Maxzina hood insulation dented the hood - Beware!
ctag
1998 Honda Civic, 2025 Ford Maverick XL 4K
The Maxzina engine bay insulation that installs to the underside of the hood uses bolts to clamp metal bars against the cutouts in the hood. After installation I can see a dent in the hood from where the bolt pushed against it. I advise you to be cautious if you want to install one of these insulating sheets.
Ford Maverick Maxzina hood insulation dented the hood - Beware! 1758319186685-bi
Ford Maverick Maxzina hood insulation dented the hood - Beware! PXL_20250919_172353700
CarbonGrayFX4
Luke
Virginia
2024 Carbon Gray XLT FX4
Oof, been there, done that. $150 for paintless dent repair left me with two small divets. You have to catch at exactly the right angle to see. I was able to find plastic rivets with plastic inserts that worked at most mounting points. I used heavy duty velcro for any saggy areas.
ctag
ctag
Are the bolts too long? Would shorter ones resolve this?
HRG
Yes and I believe shorter ones would fix it. But to be honest the whole mechanism is crap. They give you these little metal stubs to hold the material to the hood, and it just doesn't work well to begin with.
White Thunder
Donald
Sapulpa, Oklahoma
2022 Maverick XL
🤓 Doesn’t Mabett have something like that?
jorl
FLORIDA
22 Mav HYB XLT
like the idea but is the perceived effect really worth it? and then there is the notoriously "thin" metal on the truck
Dad
Thanks for the warning. Sorry you had to pioneer this problem.
Ron Dyer
Ron
Oregon
2025 Hybred
Just installed the same brand in my new Maverick hybrid. So I ran out to make sure I didn’t have any dents so far it looks good.
