Mabcim
Rochester, NY
Working! But for some reason it doesn't show anything on the right side. :crying:
That is the round euro style sign you have. It seems getting them to be the rectangular US ones has been difficult. The other one is for ‘warning’ signs and would very rarely be seen (I do not recall which signs they exactly are). But that is another reason people like the rectangular style, that 2nd sign ‘blank‘ goes away.
BlackMav23
MI
2025 Lariat (Shadow Black, 4k Tow, Sunroof)
You've got the European style enabled. I had that issue until some wonderful individuals showed me how to get the rectangular US style sign. With that style there's only one image on left. So no blank bubble on the right.
That said, you are in Brasil, yes? Having not been, I don't know what your speed limit signs look like. Rectangular signs may be of no interest to you.
If you are interested, the following worked for my XLT FX4:
  • IPC
    • Disable “Traffic Sign Recognition (TSR)”
    • Enable “Speed Limit Information Function (SLIF)”
  • IPMA
    • Set Traffic Sign Recognition (TSR) to “SLIF”
    • Set Traffic Sign Recognition Mode to “Camera Data Only”
  • From there you will have to enable it in the menus of the vehicle itself.
Obviously this was performed on an American model so there may be some differences other than the obvious metric units and different language.
benjitobz
Ben
Canada/Ontario
2024 Ford Maverick Lariat
This has been tested and will work on all models that do not have a Ford Navigation system installed. It should work on models with a Ford Navigation system but will require different settings and may also require some APIM module changes to fully integrate the Navigation sign information into the display cluster.
Tools need
Forscan software and a programming cable
Tutorial assumes you already know how to program using forscan.
Method 1 - No Ford Navigation system installed
This applies to 4 inch and 6 inch clusters, this will show the traffic speed signs as round in the 6inch clusters.
First we need to enable TSR camera function in the Image Processing Module
IPMA
706-01-01
xxxx-xxD2-xxxxx
This enables TSR in camera only mode and the sign mode being SLOIF
SLOIF = speed limit and overpass signs
Next we need to activate it in the instrument cluster
IPC
720-03-02
xxCx-xxxx-xxxx
This activates the TSR menu
Next optionally is for the speed warning menu. If you leave it default you'll get 2 tolerance options for below and above 35 MPH. If you set this it will display it as a single tolerance option.
IPC
720-10-01
xCxx xxxx xxxx
This will display it as a single option. The tolerance will flash the speed limit sign in the cluster if you are traveling that many miles or more above the posted speed limit.
Finally if you want an audible warning to going along with the tolerance setting this value will enable chimes.
IPC
720-04-01
xxxx-xx4x-xxxx
This will give an option to enable chimes in the speed warning section of the menu
Method 2 - No Ford Navigation system installed recommended for 6inch cluster screens.
Thanks to @nickn066 for pointing this out originally
This also applies to 4inch cluster screens.
This method enables Speed Sign Recognition which is a subset of TSR. It is a different menu and only applies to speed limit signs. If you have a 6 inch cluster and want the speed limit signs to be displayed as squares like in the 4inch cluster screen then use this method instead.
First we need to enable TSR camera function in the Image Processing Module there are 2 settings that will work
IPMA setting 1
706-01-01
xxxx-xxD2-xxxxx
IPMA setting 2
706-01-01
xxxx-xxD3-xxxxx
This enables TSR in camera only mode and the sign mode being SLIF
SLIF = speed limit signs only
It is recommended to use setting 2 here since the SSR menu in the IPC cluster only operates in SLIF mode.
Next and finally we just need to enable the Speed Sign Recognition menu in the cluster. By default it is disabled.
IPC
720-09-01
xxxx-xxxx-8xxx
This enables the Speed Sign Recognition menu.
Method 3 - Ford Navigation system installed.
writeup to follow
That is it and if you did everything correctly TSR which is undocumented on the Maverick thus far will be enabled and working correctly in the instrument cluster with no conflicts with other safety features.
Hey got a quick question. So I have a 2024 Lariat Hybrid and I'm 90% sure it has nav - (I see the APIM and I have a navigation screen in the media console that shows posted speed limits). I got TSR enabled easy enough but just curious if anyone has been able to get the nav systems posted limits into the drivers cluster, to clarify TSR is detecting road signs perfectly but in areas that there are no signs it doesn't update with the nav's posted speed limit.
I've enabled the follow but no luck gonna try to enable turn-by-turn navigation to see if that enables it. Think it's something in the IPC but this is all new to me:
IMPA:
706-01-01
xxxx-xxDB-xxxxx
IPC:
TSR Disabled
Camera and maps data
pa-outdoorsman
PA
2022 Maverick XLT, EB, LUX, FX4, 4K, Cactus Gray
OK folks, just did this today. Thanks to @BlackMav23 If you have the 6.5-inch cluster and use easy mode, here's what you want to do to activate speed limit sign recognition and not get the European circular signs.
If you are interested, the following worked for my XLT FX4:​
  • IPC
    • Disable “Traffic Sign Recognition (TSR)” (THIS SEEMS COUNTER-INTUITIVE, BUT IF YOU ACTIVATE TRAFFIC SIGN RECOGNITION YOU'LL GET THE CIRCULAR SIGN ICONS. YOU WANT TO DISABLE IT.)
  • IPMA
    • Set Traffic Sign Recognition (TSR) to “SLIF” (THIS IS WHERE YOU ARE TELLING THE TRUCK TO ONLY READY SPEED LIMIT SIGNS AND NOT ANY OTHER KIND OF SIGNS)
    • From there you will have to enable it in the menus of the vehicle itself. (FROM THE MENU ON THE STEERING WHEEL, GO TO "SETTINGS" then "DRIVER ASSIST" and activate Traffic Sign Recognition. Again, this is counter-intuitive, because you might be thinking, he just said to DISABLE TSR. Which I did, but somehow it'll still show up in your menu and you can turn it on and enjoy the speed limit info as you drive right next to your speedometer.
Enjoy!
pantera156
Pantera
Porto Alegre
lariat 2.0
The signs here are round, so that's fine. The right side never showed me anything.
pantera156
Pantera
Porto Alegre
lariat 2.0
  • IPC
  • IPMA
Yes, the signs here are round. So I'll leave it like that.
Very thanks!
Mabcim
Rochester, NY
I found this old Ford video. It only shows one thing for the other circle. Looks like it is for signs that would be on the opposite side of the road???
It's for Euro no passing zone signs (the black and red cars).
A.Bursell
Stanwood, WA
  • IPC
  • IPMA
Enjoy!
This worked almost perfectly for me in my 24 Lariat Eco. TSR was already disabled, so I only had to make the three changes under it. One thing to note, I did not have a "TSR" option in my driver assist setting, it seems to be always on? The only setting there was to turn on the over speed limit indicator and then how much tolerance there was compared to the speed limit. I tried it and found the blinking signs extremely annoying, so I turned it off and now just have the speed limit signs on the dash with no "nanny." Wonder why I don't have the option to turn TSR on and off??
pa-outdoorsman
PA
Who knows? But if it's working for you don't sweat it. I also found the speed warning thing annoying and turned that off as well.
mar.neumann
Marcelo
Brasil
Maverick Hybrid Lariat 2024
  • IPC
  • IPMA
Enjoy!
This is perfect...
I had followed the entire step-by-step process in the @EONR24 spreadsheet, but I still had two circles, with the first one showing the speedometer and the second one being translucent with nothing.
I did this configuration that you mentioned, along with the information from @BlackMav23 and it worked great.
Now I have round plates (I prefer round ones instead of square ones), with only 1 circle.
In addition to this, I did the AS BUILT configuration of the spreadsheet so that only 1 tolerance option appears.
Everything works, wonderful!
MAVERICK LARIAT HYBRID 2024, SYNC 2.5, CLUSTER 6,5", BRAZIL.
Ford Maverick Traffic Sign Recognition (TSR) FORScan mod (confirmed working) Captura de tela 2024-11-22 220912
flyswatter
Macon GA
2024 Ford Maverick Lariat, 2020 Lincoln MKZ
This is the first thread that made me think "maybe I do want to mess with that forscan thing."
