Tailgate not level with bed.
clavicus
I was more than paying attention. Lifted that term out of 1 of the complaint replies here. And you are implying the tailgate in down position is part of the overall bed length in your arguments. Maybe go back and proofread your diatribes before hitting "Post reply"?
We can see you have a strong opinion that is at odds with us that care about this issue. But you’re not adding anything to the thread except negativity.
Gonefishin
Jeffrey
Niceville Florida
2023 Maverick XLT Hybrid
Tailgate Down 101 Refresher Course:
From 1aauto.com
"What are tailgate cables and where are they located?
Your tailgate cables, also referred to as tailgate straps, keep your tailgate level with your truck, Jeep, or wagon when the tailgate in the back of your vehicle is open. They are bolted on at the body of the truck and connect to the tailgate with eyelets. Without them, the tailgate would swing further open and hit the bumper, which might cause damage to the vehicle. Tailgate cables also need to be strong and durable enough to support the weight of the tailgate and maintain its levelness with your vehicle even when a heavy load is placed upon it.
A worn or broken tailgate support cable may not seem like a big deal but, believe it or not, faulty tailgate cables led to one of the biggest recalls in automotive history. In 2004, General Motors had to put out a recall on three-and-a-half million trucks after over 100 drivers suffered minor accidents due to collapsed tailgates.
How do I know if my tailgate cables need to be replaced?
If your tailgate sags when open, it’s probably time for new replacement tailgate cables. Visible fraying or wear of the cables is also a good sign that they need to be replaced. "
Tailgate Down 102 Refresher Course:
From Me
If your lowered tailgate is not level with the truck bed, it's functioning as a ramp. See Ramp 101 Refresher Course.
Larrythelunatic
Larry
Massachusetts
You’re STILL not paying attention.
By the way……..
It sure sounds as if you do not wish fellow club members well. Curious as to why not.
Bj517
Nc
Lariat
when was the last time you found a perfectly flat 4x8 sheet or long plank wood at Home Depot or similar? They all seem to come pre-bent for us now. Level tailgate is a moot point here...
I was thinking more along the lines of a long piece of furniture. More fragile than a sheet of plywood.
Look, I love my maverick and can forgive/understand the compromises that go into making a truck that starts at $20k. But this isn't that. This is clearly just someone fucking up a measurement.
Grand Nat.
NYC/ L.I
Schwinn Stingray
I didn't receive my Maverick yet however my experience with other vehicles with tailgates is that there is usually an adjustment on the latch assembly and in conjunction with the striker bolt that attaches to the side of the bed quarter it may be possible to move that bolt forward to pull the cable and then adjust the latch back so the tail gate closes with out being to tight. I do not know if the latch and striker bolt it's adjustable on this vehicle. Does your tail gate body lines fit properly now when it is closed. ??:unsure:
Charles
Charles
Georgia
'17 Edge
probably because they are scared of that Class Action lawsuit you guy are planning. Either that or they figured cables were cheap price to pay to make you quit complaining and go away. Joke will be on you when replacement set also isn't perfect like you expect.
Shirley you Joke
Sleeper 7
Steven
NH
18 Fusion 14 Ram Dump 23 Maverick XL
Your reaching. Lol. Im sure you could find lots of problems with a tape measure and level. On my my 08 f150 the cab and bed were installed 3/8 inch to 1 side. You couldnt tell looking at it but the tape measure doesnt lie. The maverick is probably closer due to uni-body but frame off trucks are all way off.
JimmyH
Jimmy
2023 Ford Ranger XLT; 2023 Kia Sorento EX Hybrid
You're supposed to use the 3\4 tailgate position for your long, flat loads
I 100% agree...if I'm carrying a 4x8 flat load. Doesn't help me if I'm carrying anything narrower, say a 2x8 flat load.
Bj517
Nc
Lariat
The tailgate closes and aligns just fine. And you can't adjust the cable mount points - they're welded on. The problem is the length of the cable. It's like an inch too long.
Charles
Charles
Georgia
'17 Edge
No Tape measure required to see my issue.
Old Ranchero
CO
On the contrary, I'm adding levity to the situation as well as providing a counterpoint to what is a 1 sided argument by a vocal minority here. That's called a discussion. Please review post #260 (not mine) for a reality check. Have you guys also measured fit and finish on hood alignment, gaps on all 4 doors too? I actually did that on my 1st ever brand-new vehicle purchase in 1987- a Ford Ranger.
Dealer lots were overflowing with dozens of units in each color back in those days. I was fixated on what was a close resemblance to today's hot pepper Red. I believe there were 16 in stock and I spent a whole afternoon with ruler, pad, and pencil examining every 1. None were perfect! In the end I settled for the most aligned 1 truck I could find and figured I could adjust some of the door and hood gaps at home myself. In those days JD powers, Consumer Reports, etc. Published initial quality rankings including fit and finish with American manufacturers always bringing up the rear.
Our stamping and other processes have improved massively since then, and I can't remember even seeing that category even ranked anymore because of industry wide parity. The moral of my story is I had to learn to live with less than perfect on some aspects of my vehicles and ignore it. My Maverick has been a joy so far and the overall value and use case was spot on to my expectations, so no complaints or imperfections change the big picture here.
As always, YMMV
Charles
Charles
Georgia
'17 Edge
As always, YMMV
I’m thinking you’re trying to be the smartest person in the Chat. Your attempts to ridicule Mav owners’ legitimate concerns is Troll like. But that’s ok; a competent Troll can be entertaining. 👍
Gonefishin
Jeffrey
Niceville Florida
As always, YMMV
“Have you guys also measured fit and finish on hood alignment, gaps on all 4 doors too?” Huh? Wha?
Speaking of levity,
Wise man told me “sometimes it‘s better to keep quite and let people think you’re an idiot, then to tell your thoughts and remove all doubt.”
Just a general statement not meant to reflect on anyone here. I often don’t follow this advice. Lol.
Old Ranchero
CO
I determined before buying a Maverick wouldn't possibly meet every use case I might encounter and workarounds would be required. I share an F-150, 6' bed with my wife and purchased a 6x10 box utility trailer to mitigate limitations of Maverick short bed length. Furniture, motorcycles, bales of hay, etc. end up in the other options instead of the Maverick.
