POLL - Hybrid Transmission Grinding/Lurching
Does your Hybrid Maverick grind/lurch when stopped with foot on the brake when cold?
  • Total voters
    123
710-oil-614
Cal
2025 Hybrid AWD Lariat
I’m only 800 miles in so not a lot of wheel time but I have not experienced this at all.
The closest thing I’ve observed is that at very low speeds I can hear (but not feel) the pass of braking from motor generator to brakes. Very faint somewhat of a crunch noise.
The Real Maverick
Jack
Need to add a category.
Rarely mine will lurch when cold.
But never had anything I would call grinding.
Probably what most people mean is the sound of the brake pads. Not the transmission or engine. That's a common sound in every car if you let it "creep" just an inch with foot on the brake.
tired comet
markus
ORD
Mav XLT hybrid
Not an issue I have had so far at 29,000 miles
Potatomafia
Eastern New Mexico
2023 Ford Maverick XLT Hybrid
Mine only seems to do it when it's cold outside. I'll start it up and wait for the idle to drop before I drive it but it still lurches. It seems to go away after the engine gets to operating temperature.
skinnyboy
Andy
Ontario, Canada
Mine lurches now almost every day when below freezing, seems worse than previous years. Spoke to another hybrid owner last week, says his does the same thing.
Cheers.
Cruzer
Adrian
Santa Cruz, CA
2024 Maverick Lariat Hybrid
500 miles put on my Maverick. I notice it when I stop at a traffic light very close to my driveway after just starting it up and driving in morning. It’s gone by the next light that is 4 blocks away. When I take a different route with the first light about 10 blocks away from my house I don’t notice it. I associate it with the engine being cold.
AngryGoose
Cedar Rapids
2025 Maverick XL AWD Hybrid, 2023 DR650(Sold), 2025 GSX-S1000GT+
I've got just under 800 miles on my 2025. It does it most of the time shortly after startup and coming to a stop. It kinda buzzes, and occasionally I can stop it if I hit the brakes a little harder. It's very noticable when it's below freezing.
Typically though it won't do it once warmed up
Stradbash
SE Michigan
2005 Honda Element
I didn't respond to the poll as it doesn't have an option for what I experience, which is just some mild lurching, probably only when cold, but I've not paid attention to that.
I have no grinding whatsoever.
710-oil-614
Cal
For the people who voted that they never experienced this do you live in a place where it doesn't get below 40?
It's been as cold as -5 F here since I picked up my 2025 and I have not experienced it in any weather.
No grinding noise, unless I'm just not calling what I hear grinding to the sound of eCVT on initial cold startup.
Only felt the shimmy when cold ambient temp, engine came on from the get-go due to that, I slipped it to Neutral before the ICE RPM lowered (purely to see if an issue, normally leave in park until that RPM drop).
Observed - the generator RPM (4500 abouts) attempting to counter the engine RPM (1240 abouts) so no power to the drive wheels would cause a creep in Neutral.
Since there is no true neutral like disengaging gears - this is what it has to do to mimic it, and it caused some lurching with brakes pressed until it was warmed up in like 15-20 seconds.
I could see that perhaps having a similar effect in drive where it does attempt to keep some positive torque on wheels so the creep could work when you only light press brakes.
It needs the proper gearing for a light creep, while the generator motor is also used to do some HVB charging since the correct direction.
Maybe some sensors aren't great, and it's adjusting the generator RPM more than it needs to - the engine RPM at those times seems very steady.
Or the clutch plate is showing some problem signs.
There was a post about that, which included general instructions on getting that seated really well, and their issue never came up again. Well, or in the time the thread stopped having posts.
MavMeister25
South USA
‘25 Ford Maverick XL
Noticed this noise yesterday for first time when I was stopped at a traffic light on an incline slope. Temp was 50 degrees. Truck had just started up 1 minute prior. It went away shortly after.
nice description of clutch plate.
https://www.mavericktruckclub.com/forum/threads/2-5-hybrid-p0811-code-obd2.13063/post-260773
and the solution to perhaps slightly different issue. (maybe not)
https://www.mavericktruckclub.com/forum/threads/2-5-hybrid-p0811-code-obd2.13063/post-269298
and the result.
https://www.mavericktruckclub.com/forum/threads/2-5-hybrid-p0811-code-obd2.13063/post-272534
@mav47 - any other problems with the clutch plate since couple years ago?
(I used Google search to find that threads - MTC search not so good many times)
