- Jan 27, 2022
- Sacramento, CA
- ‘02 Ranger, ‘22 Mav XL
- Engine
- 2.5L Hybrid
That reserve seems excessive, but I’m sure they have their reasons.
I actually went 55.5 miles past DTE 0.Wow, 2.7 gallons available past zero DTE, that’s an easy 100 miles - that’s crazy!
Well then, the gunk from over the years.If you want to remove moisture, add some high proof alcohol.
Wait. Most stations already do.
Never-mind. Moisture should never be an issue. Driving through a hurricane excepted.![]()
Is that even a thing?Well then, the gunk from over the years.
Not to beat a dead horse! But you'd do well to read the Maverick manual for the right answers. My company has 4 Ford Escapes and just like the Maverick, has the no gas cap feature. As is stated in the manual, if you run out of gas, put in only about 1 1/2 gallons of gas, and crank the engine before fully filling the tank...this restores the air pressure inside the gas tank. A completely empty tank can and usually does screw up the gas tank air pressure.I actually went 55.5 miles past DTE 0.
That means DTE was not in the right "spot". But.... it's winter. Much colder recently. My MPG was on a pretty steep downward trend. Also, the past week I had the Mav up to 80 mph. For the first and second time ever. I usually keep it under 60
Pretty sure under consistent driving conditions, yes, you could have about 2.7 gallons beyond MTE 0.
This also explains why Ford published 13.8 gallons. 13.8 is what you can count on, regardless of drastic weather and driving changes.
It's neither advisable nor necessary unless you're going out of your way to push the vehicle as far as you possibly could. Even if it doesn't end up causing any harm, it rarely would do much good.Wait I thought we weren’t supposed to add more after topping it off.
Just a observation about build up of sediment. On my 1991 S10 blazer I had to replace the tank. I puncture it off roading. At the time it was 8 years old with about 90K miles. When changing the tank you remove the sending unit on top of tank. and there is a large opening at the top. I was curious to see if there was any contaminant in bottom of tank. looked clean as can be. Nothing in the bottom of the tank. So not so sure about it getting crap at the bottom. . At least not in any of my pretty old vehicle . But boy that 4.3 v6 sucked fuel 15 mpg at best.Someone made a similar post back in the spring or early summer, they ran it right out of gas and limped to a station on electric power.
All vehicles have larger tanks, as in they leave a reserve that's usually good for 50 miles or so beyond empty. Usually as a vehicle ages sediment and condensation builds up in the tank and can be found at the bottom. Not a big deal to dip into that when the truck is new, but wouldn't want to do it too often as it ages, unless you burn through all of it on a regular basis.
Maybe more of an issue in the past perhaps? In theory if the gas stations you go to get high volume there shouldn't be much of anything. All bets are off at older stations and older no-name brand stations in the middle of nowhere.Just a observation about build up of sediment. On my 1991 S10 blazer I had to replace the tank. I puncture it off roading. At the time it was 8 years old with about 90K miles. When changing the tank you remove the sending unit on top of tank. and there is a large opening at the top. I was curious to see if there was any contaminant in bottom of tank. looked clean as can be. Nothing in the bottom of the tank. So not so sure about it getting crap at the bottom. . At least not in any of my pretty old vehicle . But boy that 4.3 v6 sucked fuel 15 mpg at best.
It really comes down to a combination of factors. Improvements in filter technology on the vehicle and the pump play into the amount of sediment in the tank. So too does the turnover rate, maintenance of the tank, and maintenance of the filters at the station.Maybe more of an issue in the past perhaps? In theory if the gas stations you go to get high volume there shouldn't be much of anything. All bets are off at older stations and older no-name brand stations in the middle of nowhere.
