ListedGuru
MI
Mercury
CRC 06026, aka cosmoline. Goes on like paint and dries to a hard wax layer.
From my research there's no better product than cosmoline for new vehicles. From a few test videos online the other popular rustproofing product fluid film is gone after few weeks in the rain, the crc stuff holds on even after being pressure washed.
Ok thanks for the update. It looks like your in Canada - I'm in Michigan and we get a fair amount of snow and nice and thus a lot of road salt. Have you used cosmoline before or is this your first time using it? I'll have to research this a little more I guess. I wonder if any of the places around me that do undercoating and rustproofing use cosmoline? I'm not really a DIY person when it comes to this stuff,lol.
Block
Eric
Syracuse, ny
Ford Focus
Been using that on my 2013 Focus - haven't lately but am not driving much - teleworking.
Starting to get some surface rust underneath but typical rust areas - door lower lips, hatch, fender edges all look great.
Block
Eric
Syracuse, ny
Ford Focus
CRC 6026 comes in spray cans. I bought a pack of six as my recollection for a discount through some place who sells it on Amazon.
O'Reilly's or another local place had it one time on a good sale as well. I think I paid 10 to $13 a can but one can doesn't go very far. I might Ford Focus the thing I worry about are the springs. I think my prior to Fords I had to replace the springs as well as our caravan. I live in the snowiest 100k+ city in the USA which is Syracuse New York... Also is surely the saltiest.
Tom 71 Maverick 24
Northeast Ohio
That's the beauty of electric motors, 100% of the torque at 1 rpm. As you can see below the hybrid is quicker 45-65 mph which is every day commuting speeds. You can bet Ford set it up for low to mid speed punch. Doesn't really fall off much to the over 50 mph area.
Both charts from https://fastestlaps.com/models/ford-maverick-2-0-t
Acceleration hybrid
45 - 65 mph3.7 s
0 - 30 mph2.9 s
0 - 40 mph4.2 s
0 - 50 mph5.7 s
0 - 60 mph7.6 s
0 - 70 mph9.8 s
0 - 80 mph12.5 s
0 - 90 mph16.0 s
0 - 100 mph20.7 s
1/4 mile15.9 s @ 89.7 mph
Acceleration ecoboost
45 - 65 mph3.8 s
0 - 30 mph2.0 s
0 - 40 mph3.5 s
0 - 50 mph5.2 s
0 - 60 mph5.9 s
0 - 70 mph9.4 s
0 - 80 mph12.4 s
0 - 90 mph15.8 s
0 - 100 mph16.4 s
1/4 mile14.5 s @ 95.0 mph
Some oddities in those acceleration numbers.
The Real Maverick
Jack
Keep in mind the EB has to shift and the Hybrid doesn't.
0-80 the hybrid has torque going to the wheels all 12.5 seconds. The EB has several instances of zero torque between shifts. Fractions of a second each. But what, 7 shifts?
mamboman777
Josh
NRH, TX
I can not speak to the accuracy of the above acceleration data. Plotting the above data shows this:
Remarkably similar is the takeaway.
Shhh! Don't tell the EB owners. There'll be an uprising.
Waterick
Richard
Laurens county SC
Happy this thread got opened again, really enjoyed it. First time re-reading it after getting my Maverick. Really does show just how quick the hybrid can be with little effort and no fanfare. I have been more pleasantly surprised at my driving experience with the Maverick hybrid than I expected even after seeing this post (thread) 19 months ago.
Eagle11
Valley of the Sun
NO they will point out all the recalls our Hybrids have had, like that means a lot
LordFariat
Justin
Napa, Ca
2025 Ford Maverick Lariat Awd Hybrid 4k towing
PEAK HYBRID SYSTEM TORQUE: 267 Lb-Ft.
Published Torque:
Gas Engine: 155 lb-ft peak
Electric Motor: 173 lb-ft peak
Unpublished:
Combined hybrid system peak output.
Tested:
Peak Combined Output: 267 lb-ft
(Computer calculated)
Achieved with high (4000 RPM) engine and low (20 MPH) Motor Speed. Peak Torque is with pedal to the floor, truck at 20 MPH.
University of Nebraska did extensive testing of OBDII computer generated torque values vs. dynamometer testing, and found on a 4.5L diesel engine, OBDII computer calculations were consistently higher, but just 2% higher than dyno.
I collected data via OBDII during two full throttle accelerations from zero to 65 MPH. I only had snapshot values at 1 second intervals so the peak may be slightly higher if it occurred between intervals, but the two runs matched pretty closely.
At highway speeds, torque was about 180 Lb - Ft.
The sweet spot: 20-30 MPH.
EB Maverick can sustain the high torque for as long as gasoline supply lasts. Hybrid Maverick will only be able to sustain high torque for 1-2 minutes, or for as long as the battery charge lasts.
But at least, I have demonstrated (to myself anyway) the hybrid is just as good, as the EcoBoost, for getting your heavy load/trailer going from a stop.
Hope you enjoy reading this half as much as I enjoyed testing it.
Of worthy note: there is a stored value in your truck, like the stored value for engine displacement and manufacture date. There is an on board stored value for 100% Torque Reference Point. The value in my Hybrid Maverick: 245.6 which is close to experimental values.
My first run I got a peak of 253.6.
My second run I got 267.
Published Torque:
Unpublished:
Tested:
Curious do you have any torque info on the 2025+ version with the HF55 eCVT?
It may be time to revive this thread with a new test!
Thanks!
commod0re
Bothell, WA
2025 Maverick Lariat Hybrid
Amazing. I assumed that the published numbers meant that the electric motor only added 40 hp and 20 lbft! This proves that was way off
Mavster Mechanic
Hybrid
0-20 maybe 0-30 MPH the Hybrid will outrun the Ecoboost.
The Hybrid will tow the 4,000 lbs trailer uphill on Electric only at lower speeds.
Mavster Mechanic
Hybrid
Someone else in here stated the transmission number = the torque the transmission was able to sustain (But not necessarily what the truck puts out.)
I have not independently verified.
Seems reasonable.
Also could be a coincidence since each new generation went up by exactly 10.
2022-2024 HF45
Ford Maverick Tested: Hybrid Maverick Peak Torque = 267 Lb-Ft IMG_7019
2025-2026 HF55
Ford Maverick Tested: Hybrid Maverick Peak Torque = 267 Lb-Ft IMG_7020
EDIT:
The EcoBoost had/has a 8F35 transmission.
8 = 8 speed? (Likely)
H = Hybrid? (Likely)
Ford's "heavy duty" is 8F57?
Ford Maverick Tested: Hybrid Maverick Peak Torque = 267 Lb-Ft 1767979646664-85
It's making more sense the deeper I dive.
I said it before. HYBRIDS are WELL SUITED for towing. Transmission wise at least.
Ford Maverick Tested: Hybrid Maverick Peak Torque = 267 Lb-Ft 1767979898052-d4
Escapologist
Niagara Region, ON
Thanks!
I would also be very curious about that. Stuff elsewhere suggests quite a bump, but would like to see what same procedure as in this thread comes up with.
On "sustain" I guess that's hot weather, non-sealevel, battery depleted, worst case scenario ass coverage numbers.
710-oil-614
Cal
2025 Hybrid AWD Lariat
It doesn't suggest a bump - it is very real the new HF55 electric motors are much more powerful but that doesn't necessarily mean that all of that increase will translate 1:1 with a peak torque increase.
That said I would expect a higher peak torque number for the HF55.
https://www.wired.com/story/first-d...-pickup-way-more-americans-should-be-driving/
To deliver that performance, every component of the new HF55 hybrid transaxle (now used in all Maverick Hybrid versions) is uprated while continuing to fit within the same package size as its predecessor. Torque from the drive motor rises from 235 to 320 Newton-meters (173 to 236 pound-feet), while the generator’s power output goes from 78 to 96 kilowatts (105 to 129 horsepower).
