Hybrid true fuel tank capacity?
Maverick2112
2025 xl hybrid.
This is really surprising because Ford is usually REALLY good about getting out the most accurate and up to date information! LOL
Renho17
Ren
Hybrid Mav
it is kinda accurate, 13.8 gallons and 14.3 with reserve.
pndwind
Heart of Dixie
F450 Amb
I went to high school 63 years ago and one of my buddies worked for the state for many years verifying the metering of the gas pumps was accurate. Quite often he had to lock pumps until they were recalibrated. Was many years ago but probably still done
There were some locked near me this summer. A large busy well known station. I bet they got them fixed quick. It had to be costing them plenty of money.
LSchicago
Lloyd
IL
Just filled up for the first time with 4 miles till empty. 14.6 gallons. 420 miles so 28.8 mpg vs computer saying 33mpg. Something seems off..I’m guessing it was the pump I used.
Sounds like the pump is rigged to overcharge. report to your counties weights and measures so they can check that station.
GPSMan
Many
I filled up at two separate stations.
Two separate cities.
Both indicate a 16 gallon minimum usable volume. What's the 2.0 supposed to have? 16.5?
Not crazy to think they could have ended up the same. Or are 2.0 owners filling up with 20? 🤣🤷🏻‍♂️😂
It's not trivial. We're talking an extra 100 miles between fill ups.
And of course the manual(s) were printed more than a year before the trucks were produced. There's that.
Brian AltoBlue
Joshua tree
22 Maverick lariat
My first fill up was 15.1 gallons 516 miles
Thought fuel station over charged me but it must have a 16 gallon tank with all post over 13.8
GPSMan
Many
Was your yellow low fuel light on?
How many miles to empty or how many miles past zero did you go?
Brian AltoBlue
Joshua tree
22 Maverick lariat
Low fuel light was on 25 miles to empty 8 miles to fuel station 12 miles to empty on the screen when I filled up
Hardening2753
Ford Maverick Hybrid
So, there's actually a bunch of equipment in the gas tank of the hybrid, more than usual. It's in place to improve gas mileage. At least part of its function is to pressurize the tank. The problem is its eats up space.
As I recall, the actual tank size is in the 14 - 15 gallon range, but that equipment takes up space and it can't be totally submerged in fuel so the actual capacity is 13.8. This is why hybrid documentation is very insistent that you don't try to do a double fuel up to 'top off' the tank. Once the overflow trips the gas pumps auto-shut-off, stop.
EDIT: Oh, and 13.8 is correct as far as capacity goes. I ran this thing dry for my first fill-up and I only got 13.775 gallons in.
What's the mechanism that increases MPG through pressurized gas tank? Is it a better atomizing?
It helps keep the tank's atmosphere above the natural vapor pressure point of the gasoline so less of it evaporates.
wax87
Stuart
Dallas South
2004 Avalon
In a hybrid?
Mc_Flier
Area 51 Maverick Hybrid, Street Glide Special
Oddly, the large Owner’s Manual states 13.8 gallons and the small Quick Reference Guide (which also came with my vehicle) states 14.3 gallons. Both manuals have a July 2021 published date on the back covers. Can anyone confirm which is correct?
When I purchased my truck, we went to get fuel. I had 22 miles range remaining. She put over 14 gallons in the tank to fill.
imboden013
West Memphis AR
2024 & 2025 Mavericks
MY HYBRID HAS A 16 gallon tank, and I'm so happy! The books / publications are wrong.
No laughing at the MPG. I was towing HEAVY with also 500 lbs. in the truck in the Sierra Mountains. Steep grades.
Notice the needle is at "about"
One-Fourth.
I pumped in 12.7 gallons to first click on automatic. 12.8'to second click. 12.9 to third click and I stopped.
One-fourth more (approx.) to 12 sure looks like 16!
At the tank before I put in 15 gallons, and I was NOT empty. I filled up just past MTE 0 and did not use up the hidden reserve. On a youtube a guy wanted to see how far he could drive on EV when he ran out of gas, so he ran out of gas on purpose. He went about a gallon worth of miles before running dry. So I'm confident there is a gallon usable past MTE 0.
16 gallon tank folks, in my July 2022 build anyway.
Gpsman On another subject I see from the posted pics you have “trip2” my Maverick only shows “trip1”. Did you add this or was it already in your view settings? I’ve not been able to find it.
GPSMan
Many
Factory standard on XLT hybrid.
Trip 1 / Trip 2 / Lifetime
Lifetime is on a separate menu and is technically resettable but I probably never will.
I use trip 1 for tank
I use trip 2 for "trips"
Lifetime is in the driver assistance menu where it shows instant MPG bar. Can choose "calm" blank screen, for me EV mode screen, and so on.
imboden013
West Memphis AR
That’s way I do on my other fords but my Maverick doesn’t have the trip 2.
