- Nov 5, 2021
- British Columbia, Canada
- 2022 Maverick Hybrid
- Engine
- 2.5L Hybrid
Never had an issue myself. I nearly ran my old Camry Hybrid down to the bottom of the tank, just to see how far I could go, but it's not something I'd want to do normally. Sure wouldn't want to do it in winter, at least anywhere that it gets below freezing in case you get stuck somewhere.It really comes down to a combination of factors. Improvements in filter technology on the vehicle and the pump play into the amount of sediment in the tank. So too does the turnover rate, maintenance of the tank, and maintenance of the filters at the station.
Could just be hearsay but Costco definitely does have high turnover (seems there's a tanker there more often than not), and rumor has it they're on top of the maintenance with the filters and all. Combine that with Top Tier-rated additives, the lowest price in town, and little to no wait if you can find off-peak times at your local warehouse, and sometimes it's easiest to just stick with what you know.
Other stations surely do a decent job of keeping things in working order as well, but beware of the lower volume, rundown stations if you're concerned. Or just let the filter in the tank do its job and try not to worry about it.
