Hybrid +12V Battery Replacement
Hdang1980
Elk Grove, CA
2022 Ford Maverick Hybrid
9 weeks since battery swap with 1 incident.
Went out of town for a week long work trip. Came home and encountered the tell tale sign of no interior lights. Drove the truck for some errands and all seems well again.
Nighowl2000
Roy
Ottawa
2022 ford Maverick lariat
So just read though this post. My 2022 EB had the exact same issues after 4 months.
Deep sleep after a day or 2.
After driving, battery would go down to 12.4-12.2.
Loose interior and bed 12v lights
Auto start, stop would not work.
Loose time on stereo.
Did the BMS reset many times. Even put a solar trickle charger. Did help for year.
Only thing that solved it was putting a aftermarket battery 725cc 24F battery from Canadian Tire
Battery now is always at 12.6 -12.7v
I think the ford 12v suck and not up to the task with all the electronics.
Edit: I did also go into forscan under the BMS settings and specified the exact battery settings too.
Nighowl2000
Roy
Ottawa
Get a solar trickle charger and put it on the dash:
**Note has to be wired directly to the battery!
AOTHOTOP Solar Battery Maintainer, 9W Portable And High-Efficiency Solar Battery Charger 12 V Waterproof, Solar Panel Car Battery Charger for RV Motorcycle Boat Marine Trailer Tractor Snowmobile,etc. https://a.co/d/bQLzfFx
Hdang1980
Elk Grove, CA
Thank you for the suggestion. I park my truck in the garage though. I'm going to continue to monitor if the battery swap is the solution. So far so good.
Johnkn
MD
OP here, I'm now at 3+ months since I replaced the battery on my Hybrid with a new Diehard, zero issues....
Nighowl2000
Roy
Ottawa
Could also get a 2amp trickle charger....
xplorguy
Norman
2019 Veloster N
Will a battery maintainer (trickle charger) actually keep the 12V battery charged using the underhood jumpstart connection points?
Random
Richmond, VA
‘22 Maverick Hybrid FE Lux & ‘11Toyota Sienna XLE
I would say not consistently. I’ve done just that and then when I’m ready to come home from work it is in deep sleep. Other days it is fine.
GPSMan
Many
Go to your dealer and tell them your truck won't always start and you are getting tired of jump starting it and they will get you a new 12v battery.
Probably same make and model but you might be lucky and get a better one.
xplorguy
Norman
2019 Veloster N
Something is happening to make this inconsistent! We just don't know what. Frustrating. Wonder what the battery does if on trickle charge only for ...a month or more. And what if you leave your truck at the airport for two weeks...does it go beyond deep sleep and won't start unless jumped?
chilicoke
S2000
This morning my 3 month old Maverick's 12v battery left me stranded, no FordPass warning, car wouldn't unlock with key fob, had to use the key to unlock, and absolutely no power on anything. Currently sitting in parking lot waiting for tow truck to come give me a jump.
Needless to say going to dealer as soon as I can. Have had maybe 6-7 FordPass low batt warnings in the past.
Palms
Gus
Jensen Beach, FL
21 Mercedes GLC; 23 Maverick Hybrid Lariat
Did you have any after-market accessories installed? Best of luck.
Johnkn
MD
OP here, I'm now at 4+ months since I replaced my battery and have had zero problems....
chilicoke
S2000
Only a dashcam, but its wired to turn off with car ignition so it doesn't draw power when parked.
Have had 6-7 remote feature disabled warning from FordPass in the past, but the car always unlocked and always had power to start. I just drove the car for totalled more than 2 hours less than 18 hours ago yesterday, so it had plenty of time to charge the 12v battery up.
I was already planning to replace the OEM battery with either a deep cycle or lifepo4 pack in the future when I install a ~1500w inverter knowing how bad it is. Will try to get dealer to replace with another OEM to see if it's any better.
Ford Motor Company
Official Ford Account
Dearborn, mi
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
