Iakona
Jason
Elgin, North Dakota
2023 Maverick Tremor
I've seen some chatter over time about fog lights and the FX4 bumper, so here's my experience. Starting off I used THIS thread for a majority of the research to get me started. Antonio's work was a HUGE help. It seems like a bit of work, but 100% worth it, and works like it came on the truck.
Things purchased:
Diode Dynamics SS3 pods - HERE
JJC Offroad Brackets - HERE
F150 Headlight Switch - HERE
50' x3 16ga wire and heat shrinks for the harness
Ford Terminals for BCM Connection - HERE
Wire loom for harness to protect wire - HERE
Tons of adjustment in these brackets, so it takes a bit to get them exactly how you want it. I left mine angled out a little to match the curve of the bumper.
Cutting the bumper made me a little nervous but the JJC bezels give you some room to work with. A dremel works perfect for this. The bezels have 4 bolts that get secured from the back side.
Made the harness myself. It was pretty straight forward. Since the brackets attach to the frame you can tie up the harness to the other wires without having to have slack for removing the bumper.
Ran the wire harness through the grommet on the passenger side and down to the BCM
Next swapped the headlight switch for the F150 one so I can have the fog light button, with an oem look. Simple as popping the old one out and plugging the new one in.
You'll have to use Forscan to enable to left and right fog lights for them to work with the BCM wiring.
Pretty cool the light even shows up in the cluster like it was made for it.
Finished product
And now the real proof, the before and after. Like I said i left mine slightly angled outward to match the bumper. This might look off to some people but I welcome the extra side output to help light up ditches better.
It is 1000% worth it. I have a Tremor but used and did all the same things you did. Only difference with my fogs is I went with the SSC1's. This is the way the trucks should've came from the factory.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
For me, the added side lighting is a huge improvement. I'd do it all over again if I had to.
Iakona
Jason
Elgin, North Dakota
Agreed. I added some additional auxiliary lighting from Diode Dynamics and I got all the brackets from JJC-LLC when he had his own website, because I offroad my truck often, and the additional lighting has served me well living in rural North Dakota.
Iakona
Jason
Elgin, North Dakota
Looks great! The F-150 switch with my ditch lights is my favorite mod.
Interesting and cool use of the F150 switch. I like it. I went with a wireless light controller off of Amazon for my grille and ditch lights.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
It's more involved with installing since you need Forscan, but I wanted it to look/function like it came that way. Really even more surprised that there was even the light on the dash that works.
bgn
WA
This was my original setup as well. Much easier and much cheaper.
Carlitos_92
When you put in the SSC1s, did you use the JJC brackets that attach to the bumper cover at the bottom of the light itself? That seems to be what he is selling now, but I am a little concerned about vibrations and flexing from the bumper cover.
The SS3 brackets (and maybe JJC's older brackets for smaller lights) attach to the frame per Austin's original post.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
The ones on his ebay for the Tremor also mount with the tow hooks like mine do.
Iakona
Jason
Elgin, North Dakota
Nope because the JJC brackets for the Tremor use the tow hooks as the mounting point. They are as solid as can be. I also bought them over two years ago so I have had them a while and I have no idea what he makes now.
mtree
www.themerlintree.com
'22 Subaru Outback, '25 Maverick XLT/FX4
Moving into the '25 XLT FX4 are there any changes in the steps of this install?
Back at the start. Leads from the pods tap into which wires in the harness?
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I tapped into 6 and 7, following what was used in THIS thread.
Tbone289
I asked this question in another FX4 fog light thread with no response. Is anyone wiring in the SS3 amber backlight and, if so, how? I'm thinking I want connect mine to the parking light circuit.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Mine were the pre-backlit SS3. If I were to do it, I'd tap into the marker lights on the bumper since they're always lit when the truck is on.
mtree
Let’s see if we got this.
  • The harness you made for R & L travels along with existing lighting harness back to the BCM.
  • How does your harness connect with the BCM which is where and looks like what? Is this where the terminal repair kit is used?
  • Swap the headlight switch with one from a F-150 (or Maverick Lobo?) which has a fog light button.
  • Use existing headlight switch plug which already has the needed pins.
  • Connect via Forscan to set right front fog lamp use to fog only, set left front fog lamp use to fog only. An aside, you could disallow fogs with high bean here?
