- May 10, 2025
- Frozen Minnesota
- 2025 Maverick XLT
- Engine
- 2.0L EcoBoost
I just changed oil for the second time, very easy to do except for adding that additional tenth of a quart of oil. I tried to measure and mark on the bottle how much to add, but the bottle slipped and I added way too much. Pulled off the splash shield and went to drain a little off, bolt slipped and I drained too much. Put it back together, got it off the ramps and gave it 15 minutes, then checked the oil and was about 1/3 of a quart low. Went to add and was too lazy to grab the funnel and missed the hole. Cleaned up the mess and finally got the oil level right.
In the manual it states "If the oil level is between the maximum and minimum marks, the oil level is acceptable. Do not add oil. " and 6 quarts would certainly get it there. So I am thinking next time just throw in 6 quarts and call it good. Thoughts, or does someone have a good way to measure the additional amount to add?
