Even if they install it, they are not going to program it for you.I had almost exact similar experience. They lied. Service department wanted nearly $2,500.
There are different parts for different years? 23 vs 24?
Do your homework and make sure it is the correct one for your model year.
I'm not sure.There are different parts for different years? 23 vs 24?
@Timmyjane and @Mas280 seem to be ones who've installed ACC on a 2024 in this thread.There are different parts for different years? 23 vs 24?
Hi, could someone who successfully installed ACC, help me and share the part numbers and calibration levels of IPMA module and CCM module?
This info is in the forscan configuration tab when the vehicle is connected.
I will appreciate this info.
Trying to configure the ACC and getting u2101, control module config.incompatible.
My maverick is not US market, it should be the same IPMA, but.., maybe is not the same calibration level.
R
Fer
Did you change this line?Does anyone have it?
Just updating here --- I finally got my setup to work. So I am posting here to show how I solved my problem and found the ForScan coding that worked for my vehicle. Hopefully, that can be helpful for someone who got stuck in the process.
By no means am I trying to take anything away from the OP --- that's the bible I followed to get here! Huge shout out to the helpful post that got me on the right way. I am just sharing as an example, and giving back to the community.
My issue: my truck is XLT without 360 CoPilot. So after I did all the ForScan, there were a bunch of DTC's, and the IPMA faults out, disabling all functions. DTC's mostly point to invalid configurations in IPMA, ABS, BdyCM, etc.
My solution:
I used the "As-built Compare" tool on ForScan website (ForScan is so aweome: https://forscan.org/forum/viewtopic.php?f=16&t=4393&sid=514965409b9d34e7b2f4d9c64f94bce3), and then pulled 12 VIN's from the second hand vehicles I found on cars.com and other places, 6 are Lariat without ACC, 6 are Lariat with ACC, and compare them all to my XLT without 360.
The following is all that seems to be needed for my XLT without 360, to work with the new setup (ACC / Lane centering).
BdyCM: this is the most challenging one. I couldn't just copy over Lariat ACC codes, since then the remote doesn't work (Lariat has easy enter remote), and body controller would have DTC's since it doesn't see DC/AC inverter and other things that only Lariat's have.
I did some trial and error, and found that only this change is needed to make the body controller think there is ACC:
726-04-05: xxxx xxxx 90 from 88
ABS: Somehow there are some codes that are vehicle specific, I think they are the VIN number or something. by comparing 6 Lariat without ACC with 6 Lariat with ACC, I concluded that only the code below is needed for the ABS to think it's in an ACC vehicle:
760-03-02: x4xx xxxx xx from 2 (same with the tutorial)
IPMA: what works for me is to completely copy over a Lariat ACC Maverick codes, to make IPMA think it's a Lariat:
706-01-01: 0B4D 99C9 A9 from: 0B4D 58A9 F5 for my XLT, and Lariat without ACC
706-01-02: 2076 553A A4 from: 2075 52BA 94 for my XLT, 2075 54BA 94 for Lariat without ACC
706-01-03: xxDx xxxx, from C
706-02-01: xxxx xxxx 7F: from 60 (The ACC tutorial calls for 9F, but I looked up 6 cars with ACC, they are all 7F. 7F works for my XLT...)
706-02-02: FFC1 552A A0 from: 07C1 552A A0 for my XLT, and Lariat without ACC
IPC: although this affects what selection / displays will be on the dash and interfaces with the buttons, ultimately I think that it doesn't matter for the actual function. I used the coding from this ACC tutorial, after realizing that Lariat's probably all have the bigger dash screen, so what I found might or might not work for my 4 inch in-dash screen.
I take the notes below on what I observed of 6 Lariat ACC vs. 6 Lariat wo ACC. The coding in the OP's thread worked for my 4 inch screen --- that's actually what I kept in my truck as of now. The notes below are just for reference, and might work for 6 inch screen's (not tested).
720-01-01: xFxx xxxx xx: from C
720-01-02: xxxx 80: from 40
720-02-01: xxxx 3xxx from 2
720-02-02: 1xxx F4: from 0, A0
720-04-02: xxxx xA from x8
720-05-01: 1xxx xxxx xx from 0
720-09-01: 3xxx xxxx xx from 2
720-09-02: xxx8 xx from 0
720-10-01: x9xx xxxx from 8 (The ACC tutorial calls for D??)
SCCM: configure due to the steering wheel button changes:
724-02-01: xx90 xxxx xx from 58
PSCM: configure to let the power steering know it's in ACC vehicle, and lane keeping vibration etc.:
730-02-02: xxxx FFFF from 0000
730-02-03: FFxx xxxx from 00
So after all the coding above, all modules are clear of DTC's, and my adaptive cruise / lane centering worked perfectly! So much easier to drive on the freeway now, unbelievable.
Thank you OP for getting me on the right path! Also thank you nickn066 for helping!
How did you flash the firmware? |
Do you mind if I ask where you got the Ford firmware?using forscan beta version 2.4 with firmware update capabilitys, and of course you need a forscan license, a good adapter and the Ford firmware (I can provide for you)
The sides are not square 6 1/8" in the in the back 5 7/8" in the front for the width.Could anyone post the exact as possible dimensions of the radar unit cover? My parts arrived yesterday but no cover. Would like to start on install this weekend. I could cut out grill to approximate size and finish it later after cover comes in. Thanks. And huge thanks to everyone that has posted on this subject. You make it possible for others to attempt it.
