- First Name
- name
- Jan 13, 2022
- hinterlands
- 2022 Ford Maverick XL, AWD, 4K tow, 2.0L EcoBoost
- Engine
- 2.0L EcoBoost
The aim of this thread to collect all the information here.
https://www.mavericktruckclub.com/f...-with-forscan-and-escape-steering-wheel.7287/
Big thanks to @Tyvemattis for first figuring this out.
The steps are as follows first you will need either a steering wheel with the LH cruise control switch paired with the correct RH steering wheel switch. the following steering wheels will work.
2020 - 2023 Escape
2020 - 2023 Explorer
2021 - 2023 Bronco Sport
edit
@Mas280 has confirmed a 2020 or newer Ford Transit steering wheel is the same as a Maverick.
or any 2022 Maverick steering wheel on the higher level trims XLT and Lariat that have the switches.
If you want to keep your existing steering wheel then the part numbers for the switches to replace the stock XL switches are
LH Switch
part# SW8579
RH Switch
part# SW8576
Next post is about the actually disassembly and assembly of the steering wheel.
2020 - 2023 Escape
edit
LH Switch
part# SW8579
RH Switch
part# SW8576
