Little boy blue
Okeechobee FL
1995 ranger but getting a 2024 Maverick.
Yeah, it balances the license plate being off center. That’s what I’d go with.
I know, the license plate placement almost cause me not to buy one. I've been working on a bracket that would center the plate when you're not using the hitch.
23OxOrdered
NJ
2023 Maverick XLT - BAP and LUX package
Gotta watch how tall divider is if you put on Tonneua cover, I could not get my foldable golf cart over it without undoing tonneau cover, went from a 2x6 to 2x4 painted divider
and
DIY rails on side with eyebolt (was fun easy project finishing up can of red spray paint from divider)
All off Amazon
1.625" x 1.625" x 24 inches, 12 Gauge, (3 Pack), Galvanized Steel Strut Channel, Slotted.
3/8"-16 X 1-1/4" Shoulder Eye Bolt - Safe Work Load 1,550 lbs
3/8"-16 Cone Nuts, Strut Channel Nuts Zinc Electroplate Finish, Twirl Nuts for Use with Strut Channel (10 Pack) (3/8"-16)
WIKTOPROK 10 Pack Strut Channel Cap for 1-5/8" Strut Channel White Plastic Square End Cap Cover
Anwenk M8 Leveling Feet Stainless Steel Screw-in Furniture Leg Leveler 8mm Adjustable Table
Ford Maverick DIY Bed Divider 20240312_185203
Ford Maverick DIY Bed Divider New_20231013_01
Ford Maverick DIY Bed Divider New-20231013_02
MosesP
San Antonio
Lobo
scottjl
scottjl
Midwest USA
'25 Lariat Eruption Green, 4k, BAP
You know, putting these on the end is a good idea. you can cut it slightly short and still adjust it for a snug fit. if the wood expands/contracts from weather you can still adjust.
The Real Maverick
Jack
The license plate is the #1 easiest way to ID a truck as a Maverick at a distance.
Center the plate and you blend in with every other small truck out there.
Little boy blue
Okeechobee FL
I have one figured out that will rotate from the original spot to the spot over the hitch and back when using the hitch. It will be held in place by a magnet. I'll post it when I get it drawn out on paper
True 👍
The Real Maverick
Jack
Where do you put the plate then when you want use the hitch???
You have a 2" receiver on the back of your trailer and you put the plate there.
(it's not uncommon for trailers to have a 2" receiver. Most use it to hold bikes or extra luggage. Some pull a travel trailer and the travel trailer pulls a boat or jet-ski.)
You can pull two trailers in half the states and half the states you can't.
States like California, Alaska, Arizona, Colorado, Idaho, Nevada, New Mexico, Oregon, Utah, and Washington generally allow double towing due to their vast open spaces and long distances, making it practical for transporting goods and recreational equipment.
Where double towing is permitted, there are specific regulations regarding the length of the vehicle combination, with a range of 65 to 75 feet allowed depending on the type of trailers and vehicle.
While some states like Iowa, Kansas, Minnesota, Missouri, Montana, Nebraska, North Dakota, South Dakota, and Wyoming also permit double towing, double towing is generally prohibited on the entire East Coast, with Maryland being an exception.
At least Utah and Nevada allow triple towing for commercial drivers.
kevink
Kevin
Oklahoma
2025 Maverick
I probably saw this the same place you did. I'm probably just going to go with a 2x8 board that I already have. It just needs to be cut to length. But this looks more fuel efficient.
No Northern Tool trailer has a receiver or Harbor Freight trailer or my bike rack.
The most consumer rented trailer in the country U-Haul none of their trailers have a receiver in the back.
Ford Maverick DIY Bed Divider 20250415_085848
Even if I were to pry out the plug that the reflector is on it's too small to accept the Curt plate Mount.
Ford Maverick DIY Bed Divider 20250415_172356
Ford Maverick DIY Bed Divider 20250415_172108
I'm not saying that trailers aren't out there that have a two inch receiver.
Custom made of course commercial probably.
In my opinion the curt receiver hitch license plate holder is useless.
Having to move your license plate around because you're going to tow something. Especially when the truck has a perfectly good license plate mounting position on it.
