psuarmy
Pittsburgh
22 Maverick
I melded ideas from through out this forum and make my own flexible bed divider.
I cut wide dado slots in a cross board to match the dips in the bed. Then I made dividers that fit into the bed slots and into the dado slots. I added foam strips on the end to go into the tailgate to hold everything in place. I hinged the cross board to make it easy to remove, but will lock in place with the dividers.
You could use a 2x10, but y board is 8 1/2 high.
The cross board is 54 1/16 though you could probably go up to 1/4 inch longer.
The divider boards are 15 5/8 long.
Find the center of one of the bed slots. Make the dado cuts 1 3/4 inches wide. 7/8ths on each side of the center point.
Distance between dado cuts is 2 1/16.
Expand out both directions with as many slots as desired.
The foam strip I got is from Lowes. I have been using it for a while and it has maintained its flexibility.
https://www.lowes.com/pd/M-D-13-ft-Expand-N-Seal-Foam-Window-Weatherstrip/3434324
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2942.JPG
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2947.JPG
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2943
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2959
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2958
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2957
Ford Maverick Custom flexible bed divider DIY - Updated with specs IMG_2956
King Nothing
Jeamy
PA
2025 Ford Maverick XLT
I love this idea. I've been looking for ways to incorporate my wood working with the Maverick. I'm am definitely stealing this.
Solo
Wisconsin
'24 Maverick XLT Hybrid
I like it. And I need one. 😎👍
Hot Runr Guy
West Chicago, IL
Great idea, just need to work on a version for those of us who use a bed mat (that covers the bed slots). The use of foam against the tailgate is genius!
HRG
VICKY
Vicky
Sarasota, F
WOW this is great, last time I went to Ohio thru the mountains all the stuff
Ford Maverick Custom flexible bed divider DIY - Updated with specs {filename}
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
I love it! I echo others request for you to post the specs/dimensions if you have them
mrmagoo711
Mesa, AZ
2023 Maverick XLT Tremor
Where do I put my deposit down>
Where do I put my deposit down? lol
Alienenforcer
Rodney
Oswego, IL
2025 Ford Maverick
Thanks for sharing. This is an awesome idea. I am currently using a 2x6 that is a bit cumbersome to lift in and out. The hinge makes it more practical. For those of us that don’t have dado capabilities, I am wondering if using lattice strips tacked to the 2x6 or such with glue and brad nails at the same distances would yield the same results. Thanks again for sharing.
psuarmy
Pittsburgh
22 Maverick
I don't have dado capabilities. It is amazing what you can accomplish with a circular saw, sandpaper and some patience. A table saw with a big enough table also works. Neither are good for fine woodworking or a ton of cuts but work fine for the bed extender. Just make sure the two end cuts are straight, and the saw is set to the correct depth. You will be fine.
