Common problems - Are you concerned?
DanMustang70
FL
Mustang
I started looking up common problems for the 2.0 Ecoboost and found this article. This sounds like a real problem for a truck that will be doing some towing. Is anyone else concerned? Do you think Ford will address this issue?
2.0 EcoBoost Cracked Exhaust Manifold
Both generations of the 2.0 EB have an integrated exhaust manifold design. The manifold is made of stainless steel and integrated directly into the cylinder head. Note on European version of this engine, the exhaust manifold is not integrated, using a tradition cylinder head with individual exhaust ports and a conventional manifold.
On the 2.0 EB, exhaust gas temps can reach excessive temperatures, especially when towing or driving up grades. The constant heat cycles created by engines and fluctuating temperatures expands and contracts the stainless steel exhaust manifold. When you combine the continuous expansion and contraction with a vibrating engine, the exhaust manifold can form hairline cracks.
When an exhaust manifold cracks, air begins to seep out of the crack instead of flowing out of the exhaust. While this is not healthy for the environment, it also has significant performance and drivability implications. Turbochargers need back-pressure to operate efficiently. When the exhaust manifold cracks, all back-pressure is lost which means the turbo has to work extra hard to produce normal power levels
https://tuningpro.co/ford-2-0-ecoboost-engine-problems/
dp4616
Daniel
Sunrise, FL
2011 Ford Ranger
I am concerned. A little, as you mentioned for towing needs etc. Both engines seem to have a few quirks that need ironing out imo. The internal wet timing BELT on the 1.5l, and this on the 2.0l. I have read many good things about the 2.0 though so I am less worried about that one. This seems like an easy fix though - use the conventional cylinder head from the euro model?
Doc
Doc
Live Oak Fla
2019 Ranger, 2020 HPP mustang
Meh ..
DanMustang70
FL
Mustang
Depends if the light duty towing I'd imagine the Mav will be rated for is actually going to strain the engine at all. Towing 5000lbs with my 2.3L EcoBoost Ranger barely makes it sweat. With the right gearing, like a transmission with many gears, the engine will likely never be outside it's comfort zone.
That makes me feel better. I was concerned the engine might have a built-in design flaw. Reminded me of the BMW engine that would warp the heads because of bad design.
  • Like
Reactions: Doc
Gary in NJ
NJ
Too Many Subaru's
NOTE: this was posted before specs were known about towing.
I'm not a big fan of towing at capacity with a (gasoline) turbocharged engine. I think they are fine for loads of 50% of capacity somewhat regularly, but I would not make a habit of capacity towing with such an engine. If that's your use case, I'd look at a truck with a larger towing capacity. The Bronco Sport with the 2.0T has a towing capacity of 2,200 pounds. I suspect that the Maverick is going to fall somewhere around 3,000. That means that the Maverick will be fine towing a dirtbike trailer or something similar.
ElMaverick
S
Mazda 3
Why? especially at the lower revs is where turbos come in handy for instant torque
Old Ranchero
CO
what about Torque Steer? Nobody has even mentioned it, but it is inherent negative characteristic of transverse mounted FWD. I can't imagine adding twin turbos not making it worse. I-3 with cylinder deactivation seems un-wise. Only known work arounds are full time AWD or low mounted flat boxer configuration motors like Subaru.
Gary in NJ
NJ
Too Many Subaru's
Because turbos are also good at instant heat. Under towing loads turbos work harder to generate necessary power, which in turn generates additional heat. That heat generated during a long duration can damage the head gasket, cause premature wear to bearings and eats fuel like no V8 can.
dano0726
Daniel
NW Houston
2011 Jeep JK Wrangler Sport
If that Bronco Sport Badland's 2.0L is available in the Maverick = order this engine (unless maybe a hybrid, depending on specs)...
I finally got to highway drive Wifey's Badlands, and the 2.0L does just fine -- this is our 1st Ford vehicle, and the Badlands feels/handles really well (and planted on the road) with ample torque.
motoretro
Mid-MI
Subie
There appears to be a Class Action Lawsuit on the 2.0 Eco-Boost engine in specific Ford vehicles, I believe it may have been filed earlier this year and affects engines up to 2019. Is this the same engine used in the Bronco Sport and Maverick? If so, is anyone aware of a design change in the engine for these two vehicles? I've also seen write ups on carbon buildup from the Direct Injection system, sounds like a good recommendation for Tier one Premium fuel. In my state, that would add approximately .60 to the gallon.
Hot Runr Guy
West Chicago, IL
Pre-July 2019 1.5 & 2.0 4-cyl EB's suffered from "coolant intrusion", due to the head gasket failing between cylinders. There was a saw cut in the block, that after July 2019 was changed to a drilled hole design. I had a 1.5EB replaced at 25K in my Escape (6 weeks), but I have heard of no problems since then with the updated design.
HRG
theek
Michael
Ottawa Canada
Honda CR-V, Subaru CrossTrek
HRG
6 weeks? It took that long to repair?
motoretro
Mid-MI
Subie
Sounds like a complete long-block exchange, as long as the issue has been corrected. I know my local Toyota dealer, use only Master-techs w/ lots of experience to do the work on large projects such as long block exchanges, frame replacements, etc. It does take time, especially if all of the parts have not arrived or wrong ones were ordered.
